When searching the past logs for a particular time, is there a way to get the entire log to show instead of a little chunk in order to avoid the click and scroll endless loop needed to get to the desired part?
Not currently. If you know the particular apps/devices, you can filter on them to help suppress the white noise (assuming you're on the 2.3.3.X firmware version).
Sometime what I'm looking for is what was happening on the hub at the time of concern. (I want to look at the white noise)
Yeah...that's one of the limitations of the hub (I presume due to memory constraints or just the amount of processing time that would be needed to load all the logs at once). This is the one reason I have my logs going to a Splunk instance as it's purpose built for it. That's not always feasible for folks though since you need an always on machine. I do know that influxDB and Grafana are alternate free options that can be ran on a RaspberryPi.
It's not that essential to me to justify going down that path. I just found it annoying when it occurs. I thought maybe there was a simple solution.
