My main workhorse is still my C4 . I have all my dashboard stuff on the C4 as well. I would like to be able to reference or use the value of a variable on either my C5 or C7. They are all on the same router. Any suggestions on how to pass a value from one hub to another? Could I do it with a connector?
One possible way is to use virtual devices and hub mesh. You can use a virtual switch to represent a Boolean. You can pass some values with a virtual dimmer or sensor.
I'm sure there's a better way but that was just off the top of my head.
You can use connectors shared across hubmesh or
Two great suggestions. Thanks for the tips. I will give each a try.
You can? I looked at Hub Mesh before I replied but don't see any of my connectors as being sharable. As for the Variable Sync I knew there was a better way.
I only tested with Hub Variables, but any device (which includes connectors) should be sharable across hub mesh.
