Parse function with encapsulated commands
I'm trying to understand encapsulated commands.
Question on the parse function.
In the below zwave.parse(description,.....
Does this limit the "parsing" to command classes 0x31, 0x32 and 0x60 ?
	def result = null
	def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
	if (cmd) {
		result = createEvent(zwaveEvent(cmd))
	if (result) {
		logDebug "Parse returned ${result?.descriptionText}"
		return result
thanks
John
No, anything the device sends will still come in. What it does do is specify the command class version you want the command to get parsed as. I normally go for the lowest version that has all the features I need (because the code is more re-usable among different drivers and there's no point in doing more, IMHO), but anything equal to or lower the maximum supported by the hub or device should work.
Your example is a bit unusual though will likely work for simple cases. Often you'll pass the result of zwave.parse() to a number of overloaded methods (i.e., with the same name that accept different parameters), where the parameters differ by the command class and version (Hubitat classes corresponding to these) that you are looking for, ideally the ones you've specified.
This document has a concrete example:
Thank you again, you've helped me many times.
FYI, the full code is below. Its one of the many drivers for the Aeon Energy meter "HEM". I know the built-in driver works fine but I want it to do some different things so my goal is to get one of the existing working then add what I need.
 *  Aeon HEM      https://github.com/cdhawan/Aeon-HEM
 *  Copyright 2014 Barry A. Burke
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Aeon Home Energy Meter (US)
 *  Author: Barry A. Burke
 *  Contributors: Brock Haymond: UI updates
 *  Genesys: Based off of Aeon Smart Meter Code sample provided by SmartThings (2013-05-30). Built on US model
 *			 may also work on international versions (currently reports total values only)
metadata {
	// Automatically generated. Make future change here.
	definition (
		namespace: 	"Green Living",
		category: 	"Green Living",
		author: 	"Barry A. Burke"
    	capability "Energy Meter"
		capability "Power Meter"
		capability "Configuration"
		capability "Sensor"
        capability "Refresh"
        capability "Polling"
        attribute "energy", "number"
        attribute "power", "number"
        attribute "energyDisp", "string" // Total Kwh
        attribute "energyOne", "string"
        attribute "energyTwo", "string"
        attribute "powerDisp", "string"  //Current usage in Watts
        attribute "powerOne", "string"
        attribute "powerTwo", "string"
		command "reset"
        command "configure"
        command "refresh"
        command "toggleDisplay"
		fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
     // SmartThings tiles etc deleted.
    preferences {
        input "voltage", "number", title: "Voltage (120)", /* description: "120", */ defaultValue: 120
    	input "kWhCost", "string", title: "\$/kWh (0.11)", description: "0.11", defaultValue: "0.11" as String
    	input "kWhDelay", "number", title: "kWh report seconds (60)", /* description: "120", */ defaultValue: 120
    	input "detailDelay", "number", title: "Detail report seconds (30)", /* description: "30", */ defaultValue: 30
		input "enableLog", "boolean", title: "Enable Logging", /* description: "false", */ defaultValue: false
}  // end metadata
def installed() {
	state.display = 1
	reset()						// The order here is important
	configure()					// Since reports can start coming in even before we finish configure()
	refresh()
def updated() {
	configure()
	resetDisplay()
	refresh()
	def result = null
	if (cmd) {
	if (result) {
		return result
def zwaveEvent(hubitat.zwave.commands.meterv1.MeterReport cmd) {
    def dispValue
    def newValue
    def formattedValue
    def MAX_AMPS = 220
    def MAX_WATTS = 24000
	def timeString = new Date().format("h:mm a", location.timeZone)
    logDebug "cmd.meterType ${cmd.meterType}"
    logDebug "cmd.scale ${cmd.scale}"
    logDebug "cmd.scaledMeterValue ${cmd.scaledMeterValue}"
    if (cmd.meterType == 1) {  // Orignal value 33 not working, device seems returing meterType = 1
		if (cmd.scale == 0 && cmd.scaledMeterValue != null) {
        	newValue = (Math.round(cmd.scaledMeterValue * 100) / 100);
            state.energyTotalInDevice = newValue;
            newValue = newValue - state.energyTotalInDeviceAtReset;
        	if (newValue != state.energyValue) {
        		formattedValue = String.format("%5.2f", newValue)
    			dispValue = "${formattedValue}\nkWh"
                sendEvent(name: "energyDisp", value: dispValue as String, unit: "", descriptionText: "Display Energy: ${newValue} kWh", displayed: false)
                state.energyValue = newValue
                BigDecimal costDecimal = newValue * ( kWhCost as BigDecimal )
                def costDisplay = String.format("%5.2f",costDecimal)
                state.costDisp = "Cost\n\$"+costDisplay
                if (state.display == 1) { sendEvent(name: "energyTwo", value: state.costDisp, unit: "", descriptionText: "Display Cost: \$${costDisp}", displayed: false) }
                [name: "energy", value: newValue, unit: "kWh", descriptionText: "Total Energy: ${formattedValue} kWh"]
		else if (cmd.scale == 1 && cmd.scaledMeterValue != null) {
            newValue = Math.round( cmd.scaledMeterValue * 100) / 100
    			dispValue = "${formattedValue}\nkVAh"
                sendEvent(name: "energyDisp", value: dispValue as String, unit: "", descriptionText: "Display Energy: ${formattedValue} kVAh", displayed: false)
				[name: "energy", value: newValue, unit: "kVAh", descriptionText: "Total Energy: ${formattedValue} kVAh"]
		else if (cmd.scale==2 && cmd.scaledMeterValue != null) {
        	newValue = Math.round(cmd.scaledMeterValue)		// really not worth the hassle to show decimals for Watts
            if (newValue > MAX_WATTS) { return }				// Ignore ridiculous values (a 200Amp supply @ 120volts is roughly 24000 watts)
        	if (newValue != state.powerValue) {
    			dispValue = newValue+"\nWatts"
                sendEvent(name: "powerDisp", value: dispValue as String, unit: "", descriptionText: "Display Power: ${newValue} Watts", displayed: false)
                if (newValue < state.powerLow) {
                	dispValue = newValue+"\n"+timeString
                	if (state.display == 1) { sendEvent(name: "powerOne", value: dispValue as String, unit: "", descriptionText: "Lowest Power: ${newValue} Watts")	}
                    state.powerLow = newValue
                    state.powerLowDisp = dispValue
                if (newValue > state.powerHigh) {
                	if (state.display == 1) { sendEvent(name: "powerTwo", value: dispValue as String, unit: "", descriptionText: "Highest Power: ${newValue} Watts")	}
                    state.powerHigh = newValue
                    state.powerHighDisp = dispValue
                state.powerValue = newValue
                [name: "power", value: newValue, unit: "W", descriptionText: "Total Power: ${newValue} Watts"]
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def dispValue
	def newValue
	def formattedValue
    def MAX_AMPS = 220
   	if (cmd.commandClass == 50) {
   		def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1]) // can specify command class versions here like in zwave.parse
		if (encapsulatedCommand) {
			if (cmd.sourceEndPoint == 1) {
				if (encapsulatedCommand.scale == 2 && encapsulatedCommand.scaledMeterValue) {
					newValue = Math.round(encapsulatedCommand.scaledMeterValue)
					formattedValue = newValue as String
					dispValue = "${formattedValue}\nWatts"
					if (dispValue != state.powerL1Disp) {
						state.powerL1Disp = dispValue
						if (state.display == 2) {
							[name: "powerOne", value: dispValue, unit: "", descriptionText: "L1 Power: ${formattedValue} Watts"]
				else if (encapsulatedCommand.scale == 0 && encapsulatedCommand.scaledMeterValue){
					newValue = Math.round(encapsulatedCommand.scaledMeterValue * 100) / 100
            		state.energyOneInDevice = newValue;
            		newValue = newValue - state.energyOneInDeviceAtReset;
					if (dispValue != state.energyL1Disp) {
						state.energyL1Disp = dispValue
							[name: "energyOne", value: dispValue, unit: "", descriptionText: "L1 Energy: ${formattedValue} kWh"]
				else if (encapsulatedCommand.scale == 1 && encapsulatedCommand.scaledMeterValue){
							[name: "energyOne", value: dispValue, unit: "", descriptionText: "L1 Energy: ${formattedValue} kVAh"]
			else if (cmd.sourceEndPoint == 2) {
				if (encapsulatedCommand.scale == 2 && encapsulatedCommand.scaledMeterValue != null){
                    if (newValue > MAX_WATTS ) { return }
					if (dispValue != state.powerL2Disp) {
						state.powerL2Disp = dispValue
							[name: "powerTwo", value: dispValue, unit: "", descriptionText: "L2 Power: ${formattedValue} Watts"]
				else if (encapsulatedCommand.scale == 0 ){
                    state.energyTwoInDevice = newValue;
            		newValue = newValue - state.energyTwoInDeviceAtReset;
					if (dispValue != state.energyL2Disp) {
						state.energyL2Disp = dispValue
							[name: "energyTwo", value: dispValue, unit: "", descriptionText: "L2 Energy: ${formattedValue} kWh"]
				else if (encapsulatedCommand.scale == 1 ){
							[name: "energyTwo", value: dispValue, unit: "", descriptionText: "L2 Energy: ${formattedValue} kVAh"]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
    def dispValue
    def newValue
    if (cmd.sensorType == 4) { // Power
		if (cmd.scale == 0 && cmd.scaledSensorValue != null) {
        	newValue = Math.round(cmd.scaledSensorValue)		// really not worth the hassle to show decimals for Watts
def zwaveEvent(hubitat.zwave.Command cmd) {
	// Handles all Z-Wave commands we aren't interested in
    logDebug("Unhandled event ${cmd}")
def refresh() { // Request HEMv2 to send us the latest values for the 4 we are tracking
	logDebug "refresh()"
	delayBetween([
		zwave.meterV2.meterGet(scale: 0).format(),		// Change 0 to 1 if international version
		zwave.meterV2.meterGet(scale: 2).format(),
		zwave.meterV2.meterGet(scale: 4).format(),
		zwave.meterV2.meterGet(scale: 5).format()
    resetDisplay()
def poll() {
	logDebug "poll()"
	refresh()
def toggleDisplay() {
	logDebug "toggleDisplay()"
		state.display = 2
	else {
		state.display = 1
    logResetDataState()
	resetDisplay()
def resetDisplay() {
	logDebug "resetDisplay() - energyL1Disp: ${state.energyL1Disp}"
	if ( state.display == 1 ) {
		sendEvent(name: "powerOne", value: state.powerLowDisp, unit: "")
    	sendEvent(name: "energyOne", value: state.lastResetTime, unit: "")
    	sendEvent(name: "powerTwo", value: state.powerHighDisp, unit: "")
    	sendEvent(name: "energyTwo", value: state.costDisp, unit: "")
	else {
		sendEvent(name: "powerOne", value: state.powerL1Disp, unit: "")
    	sendEvent(name: "energyOne", value: state.energyL1Disp, unit: "")
    	sendEvent(name: "powerTwo", value: state.powerL2Disp, unit: "")
    	sendEvent(name: "energyTwo", value: state.energyL2Disp, unit: "")
def logResetDataState() {
    logDebug("energyTotalInDeviceAtReset: " + state.energyTotalInDeviceAtReset);
    logDebug("energyTwoInDeviceAtReset: " + state.energyTwoInDeviceAtReset);
    logDebug("energyOneInDeviceAtReset: " + state.energyOneInDeviceAtReset);
    logDebug("energyTotalInDevice: " + state.energyTotalInDevice);
    logDebug("energyTwoInDevice: " + state.energyTwoInDevice);
    logDebug("energyOneInDevice: " + state.energyOneInDevice);
def reset() {
	logDebug "reset()"
	state.energyValue = -1
	state.powerValue = -1
    state.powerHigh = 0
    state.powerHighDisp = ""
    state.powerLow = 99999
    state.powerLowDisp = ""
    state.energyL1Disp = ""
    state.energyL2Disp = ""
    state.powerL1Disp = ""
    state.powerL2Disp = ""
    logResetDataState()
    state.energyTotalInDeviceAtReset = state.energyTotalInDevice;
 	state.energyOneInDeviceAtReset = state.energyOneInDevice;
 	state.energyTwoInDeviceAtReset = state.energyTwoInDevice;
    if (!state.energyTotalInDeviceAtReset) { state.energyTotalInDeviceAtReset = 0; }
    if (!state.energyOneInDeviceAtReset) { state.energyOneInDeviceAtReset = 0; }
    if (!state.energyTwoInDeviceAtReset) { state.energyTwoInDeviceAtReset = 0; }
    if (!state.display) { state.display = 1 }	// Sometimes it appears that installed() isn't called
    def dateString = new Date().format("M/d/YY", location.timeZone)
	state.lastResetTime = "Since\n"+dateString+"\n"+timeString
	state.costDisp = "Cost\n--"
    resetDisplay()
    sendEvent(name: "energyDisp", value: "", unit: "")
    sendEvent(name: "powerDisp", value: "", unit: "")
// No V1 available
	def cmd = delayBetween( [
		zwave.meterV2.meterReset().format(),			// Reset all values
		zwave.meterV2.meterGet(scale: 0).format(),		// Request the values we are interested in (0-->1 for kVAh)
	], 1000)
    cmd
    configure()
def logDebug(String message) {
	if (settings.enableLog == 'true') {
    	log.debug message
def logDebug(List<String> message) {
    	log.debug message
def configure() {
	logDebug "configure()"
	Long kDelay = settings.kWhDelay as Long
    Long dDelay = settings.detailDelay as Long
    Long voltage = settings.voltage as Long
    if (kDelay == null) {		// Shouldn't have to do this, but there seem to be initialization errors
		kDelay = 15
	if (dDelay == null) {
		dDelay = 15
    if (voltage == null) {
		voltage = 120
	def cmd = delayBetween([
//    	zwave.configurationV1.configurationSet(parameterNumber: 255, size: 1, scaledConfigurationValue: 2).format(),      // Reset factory defaults
//		zwave.configurationV1.configurationSet(parameterNumber: 100, size: 1, scaledConfigurationValue: 0).format(),		// reset to defaults
		zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: voltage).format(),
		zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(),			// Disable (=0) selective reporting
//		zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: 5).format(),			// Don't send whole HEM unless watts have changed by 30
//		zwave.configurationV1.configurationSet(parameterNumber: 5, size: 2, scaledConfigurationValue: 5).format(),			// Don't send L1 Data unless watts have changed by 15
//		zwave.configurationV1.configurationSet(parameterNumber: 6, size: 2, scaledConfigurationValue: 5).format(),			// Don't send L2 Data unless watts have changed by 15
//      zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: 1).format(),			// Or by 5% (whole HEM)
//		zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: 1).format(),			// Or by 5% (L1)
//      zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 1).format(),			// Or by 5% (L2)
//		zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6145).format(),   	// Whole HEM and L1/L2 power in kWh
//		zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: kDelay).format(), 	// Default every 120 Seconds
//		zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 1573646).format(),  // L1/L2 for Amps & Watts, Whole HEM for Amps, Watts, & Volts
//		zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: dDelay).format(), 	// Defaul every 30 seconds
		zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6149).format(),   	// All L1/L2 kWh, total Volts & kWh
		zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: kDelay).format(), 	// Every 60 seconds
		zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 1572872).format(),	// Amps L1, L2, Total
		zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: dDelay).format(), 	// Every 30 seconds
		zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 770).format(),		// Power (Watts) L1, L2, Total
		zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 10).format() 		// every 10 seconds
	], 2000)
	logDebug cmd
	cmd
//   --- eof ---
