@mike.maxwell I put together a stripped-down version of the parent and child devices to demonstrate the issue. The parent creates 2 zones (main and zone 2). And for the sake of simplicity, the child only implements the mute attribute and mute/unmute only affect the main zone
In short:
If I send the EISCP message directly from the parent using hubitat.device.HubAction everything works as expected and the parent receives the response via the parse callback
If I send the EISCP message from the child by calling a method in the parent (which in turn uses hubitat.device.HubAction), the parent's parse callback never occurs.
Parent Device
metadata
definition (name: "Test Onkyo Multi-Zone Receiver", namespace: "SteveV", author: "Steve Vibert")
capability "Initialize"
capability "Telnet"
preferences
input name: "onkyoIP", type: "text", title: "Onkyo IP", required: true, displayDuringSetup: true
input name: "eISCPPort", type: "number", title: "EISCP Port", defaultValue: 60128, required: true, displayDuringSetup: true
input name: "debugOutput", type: "bool", title: "Enable debug logging", defaultValue: true
def sendTelnetMsg(String msg)
log.debug "parent::sendTelnetMsg ${msg}"
return new hubitat.device.HubAction(msg, hubitat.device.Protocol.TELNET)
void parse( description)
log.debug "parent::parse ${description}"
def initialize()
String ip = settings?.onkyoIP as String;
Integer port = settings?.eISCPPort as Integer;
log.debug "Opening telnet connection with ${ip}:${port}"
telnetConnect(ip, port, null, null);
// If the parent sends a telnet message all works as expected and the response comes in
// via the parent's parse callback
String cmd = getEiscpMessage("AMTQSTN");
sendTelnetMsg(cmd);
def installed()
log.warn "parent::installed..."
initialize()
def reset()
log.warn "parent::reset..."
def updated()
log.info "parent::updated..."
log.debug "calling createChildDevices..."
createChildDevices()
initialize()
def createChildDevices()
log.debug "parent::createChildDevices..."
// def zoneList = ["Main", "Zone 2", "Zone 3"]
def zoneList = ["Main", "Zone 2"]
try
zoneList.each { it ->
log.debug "Checking for existance of child ${childName}"
String childName = it;
def child = getChildDevice(childName);
if(child == null)
log.debug "Child ${childName} does not exist. Creating..."
createChildDevice(childName, "Test Onkyo AVR Zone")
else
log.debug "Child ${childName} already exists. Skipping..."
catch(ex)
log.error "createChildDevices caused the following exception: ${ex}";
private def getChildDevice(String zoneName)
def child = null
try
childDevices.each { it ->
if(it.deviceNetworkId == "${device.deviceNetworkId}-${zoneName}")
child = it;
return child;
catch(ex)
log.error "getChildDevice caused the following exception: ${ex}";
return null;
private void createChildDevice(String zoneName, String type)
try
def child = addChildDevice("${type}", "${device.deviceNetworkId}-${zoneName}",
[label: "${zoneName}", isComponent: false, name: "${zoneName}"])
log.trace "Child device with network id: ${device.deviceNetworkId}-${zoneName} successfully created."
catch(ex)
log.error "createChildDevice caused the following exception: ${ex}"
// The following was borrowed from Mike Maxwell's SmartThings Onkyo driver code - thanks Mike!
/* This is where I construct the entire message character by character. Each char is represented by a 2 disgit hex value */
def getEiscpMessage(command)
def sb = StringBuilder.newInstance()
def eiscpDataSize = command.length() + 3 // this is the eISCP data size
def eiscpMsgSize = eiscpDataSize + 1 + 16 // this is the size of the entire eISCP msg
sb.append("ISCP")
// the following are all in HEX representing one char
// 4 char Big Endian Header
sb.append((char)Integer.parseInt("00", 16))
sb.append((char)Integer.parseInt("10", 16))
// 4 char Big Endian data size
// the official ISCP docs say this is supposed to be just the data size (eiscpDataSize)
// ** BUT **
// It only works if you send the size of the entire Message size (eiscpMsgSize)
// Changing eiscpMsgSize to eiscpDataSize for testing
sb.append((char)Integer.parseInt(Integer.toHexString(eiscpDataSize), 16))
//sb.append((char)Integer.parseInt(Integer.toHexString(eiscpMsgSize), 16))
// eiscp_version = "01";
sb.append((char)Integer.parseInt("01", 16))
// 3 chars reserved = "00"+"00"+"00";
// eISCP data
// Start Character
sb.append("!")
// eISCP data - unittype char '1' is receiver
sb.append("1")
// eISCP data - 3 char command and param ie PWR01
sb.append(command)
// msg end - this can be a few different cahrs depending on your receiver
// my NR5008 works when I use 'EOF'
//OD is CR
//0A is LF
[CR] Carriage Return ASCII Code 0x0D
[LF] Line Feed ASCII Code 0x0A
[EOF] End of File ASCII Code 0x1A
//works with cr or crlf
sb.append((char)Integer.parseInt("0D", 16)) //cr
return sb.toString()
Child Device
metadata
definition (name: "Test Onkyo AVR Zone", namespace: "SteveV", author: "Steve Vibert")
attribute "mute", "string"
command "sendRawDataCommand", ["e.g. PWR01 (Main Zone Power On - See Onkyo EISCP Spec)"]
preferences
void parse(String description)
log.debug "child::parse ${description}"
if(description == "AMT01")
log.info "${device.getName()} is unmuted";
sendEvent(name: "mute", value: "muted");
else if(description == "AMT00")
sendEvent(name: "mute", value: "unmuted");
def initialize()
log.warn "child::initialize..."
sendCommand( "AMTQSTN" );
def installed()
log.warn "child::installed..."
initialize()
def updated()
log.info "child::updated..."
if (debugOutput)
runIn(1800,logsOff)
initialize()
def logsOff()
log.warn "child::debug logging disabled..."
def mute()
// For testing purposes this sends command to main zone regardless of the actual child zone.
sendCommand("AMT01");
def unmute()
sendCommand("AMT00");
def sendRawDataCommand(String cmd)
sendCommand(cmd)
def sendCommand(String command)
log.debug "child::sendCommand - calling parent.getEiscpMessage for command: ${command}..."
String cmd = parent.getEiscpMessage(command);
log.debug "child::sendCommand - calling parent.sendTelnetMsg with EISCP: ${cmd} "
// We can't hubitat.device.HubAction from a child device so we'll call parent's sendTelnetMsg method.
// Unfortunately, this doesn't work and the telnet message doesn't appear to be sent to the AVR
parent.sendTelnetMsg(cmd);
