Pairing steps for (Signify's) Philips EasyAir SNS410 MC (Master Connect)
Hi all,
Yesterday, I added a led luminaire controlled by a Philips EasyAir SNS410 MC to my hubitat hub. The Philips EasyAir SNS410 MC is a zigbee tranceiver for wireless control of luminaires.
Took a while to find the pairing steps, so I thought to document them here. You do need the app "Philips MasterConnect" on your (android) phone (with bluetooth enabled).
Signify Netherlands B.V.
Steps (https://www.docs.lighting.philips.com/en_gb/oem/download/connected-lighting-solutions/user-manual-easyair-sns210-mc.pdf)
  • The luminaires must be powered ON for more than 15 seconds.
  • Power OFF mains for more than 10 seconds but less than 15 seconds (disconnect device form mains)
  • Power ON mains for 2 to 3 seconds (reconnect device to mains)
  • Repeat above process for 4 times
  • On the 5th cycle, leave the fixtures powered ON at the end.
  • You should see a short dim-down/dim-up signal. Sensors are now in Safe Mode.
  • Scan with “Device Maintenance” to discover the sensors that are now In Safe Mode and Reset them,
The luminaires were discovered as "Device", I manually switched to "Advanced Zigbee Bulb" and it is working like a charm.
