Lately (several months) dashboards have been loading slow. On the order of 20 - 30 seconds sometimes. The main dashboard has 7 switch buttons and two garage door buttons. Turning on a light will take 10 seconds. I have a button (zigbee) that I use to turn a couple of lights and that takes upwards to a minute to work. Just a bit ago I was trying to install "The Flasher" app and got a HTTP memory error. I don't have that much going on, at least I don't think I do. What can I check or change to make it better? FW is up to date
On the dashboard, have you only selected the devices you want to display or left it as all devices.
If all, change it to the devices you want to display.
I see that I have all devices authorized in the dashboards. I don't find a way to remove the devices I do not need
Go to apps, Hubitat Dashboard, and select a dashboard.
There should be a selection box "Choose Devices" where you can click on, and it will allow you to edit your selections.
Thanks I found it and now cleaning up a bunch of dashboards
That appeared to work. I had several old dashboards from the time ALL devices were allowed by default, cleaning that up has spd up the page loading by a bunch.
Thanks guys
