Ouvopo Contact Sensors
I bought some inexpensive contact sensors. They claim to be compatible with Hubitat, they pair as 'device', I change it to 'generic contact sensor (no temp)' and re-pair the device and the settings come up perfectly. For a brief moment, while the device is still in 'pairing-mode', I can correctly see the state change from 'open' to 'close' as expected. Once the device moves out of pairing mode, it is stuck on the last state before leaving 'pairing-mode'. Anyone else have this kind of issue?
Found the issue.. same as another I found.. Sonoff SNZB-01P not staying connected to C-8 - #37 by Jose_R
So just to confirm - you reset/re-pair per below and it's working w/the generic contact sensor driver.
I reset the device without deleting the device from Hubitat. And yes re-pair.
Not sure if it plays a part, but NOT clicking on the "view device" link after pairing seemed to influence the driver... maybe
Does this happen every time or just woth some pairings and devices.
I just added one as a generic contact sensor and it has been working for a couple hours. It is the first device i have added to the new C8 hub.
Any chance we will get official drivers?
