Outlet (Zigbee) Power Monitoring Issue
Hello everyone, I really don't know what the problem is with the zigbee plugs, I have 4 of different brands, all with the consumption measurement option and all with the same problem that they only measure consumption when given the option to refresh . I have one more on the way but I think it will be the same problem. is there really a solution to this?
Greetings.
Which brands? And which driver? Built-in or custom?
Good, thanks for the interest.
I have ledvance, bliztwolf and 2 different models of tuya I also tried the philips. Controller I use the generic zigbee outled, this gives the consumption measure but only when I refresh.
These may need device-specific drivers because they aren't on the List of Compatible Devices.
did you click configure after changing the driver?
Yes of course.
Regards
For if it helps, the only one I found that gives all the values ​​instantly is this, but the values ​​are not correct.
GitHub - jimcghee/Hubitat-PeanutPlug: Securifi Peanut Plug originally by pakmanw@sbcglobal.net for Sma
Greetings.
any ideas to solve this? Cheers
for now you're going to have to stick with outlets on the compatible devices list or configure a rule to refresh these devices as needed.
ok, I understand that it is something known and that it will be resolved at some point? on the other hand, as it would be to make a refreshment every minute, I don't see the option as a trigger in RM. Cheers
