Is it possible to add "2 Watt" to the power reporting for outlets and switches built in drivers? Or is this built into the device and not possible? Reason is if one has a device that has real <5 watt changes you need to set to 1 Watt. If I set to 1 Watt the small fluctuations make the outlet spam the hub with unnecessary power readings.
I question the accuracy and stability of these things to measure 1 watt differences anyway and it being an integer.
