Hi,
I can't seem to get my Orvibo switches working after a recent update in the last few weeks. Using the "Generic Zigbee Switch" device type that I've been using for over a year, both my Orvibo switches no longer work. Moreover, nothing shows in the logs when I try to turn on or off.
I've removed and re-paired one of the devices to see if that would solve the issue, and I'm able to re-pair successfully but still unable to control the devices.
I've also tried switching to the custom zigbee generic drivers ([Release] Generic Zigbee Drivers with Presence and Recovery) which does seem to send a zigbee command, but doesn't do anything.
Any ideas?
dev:3552020-09-04 12:21:37.152 pm debugsendZigbeeCommands(cmd=[he cmd 0x7B66 0x01 0x0006 0x01 {} {}, delay 200])
dev:3552020-09-04 12:21:37.147 pm debugonOffCommand(command=1)
dev:3552020-09-04 12:21:37.145 pm debugon()
dev:3552020-09-04 12:21:23.376 pm debugsendZigbeeCommands(cmd=[zdo bind 7B66 1 0x01 0x0006 {00124B00092B1A85} {}, delay 200, zdo send 7B66 1 0x01, delay 200])
dev:3552020-09-04 12:21:23.368 pm debugsendZigbeeCommands(cmd=[he raw 7B66 0 0 0x0005 {00 667B} {0x0000}, he raw 0x7B66 1 0x01 0x0000 {10 00 00 05 00}, delay 2000])
dev:3552020-09-04 12:21:23.366 pm debugrefresh cmd: [he raw 7B66 0 0 0x0005 {00 667B} {0x0000}, he raw 0x7B66 1 0x01 0x0000 {10 00 00 05 00}, delay 2000]
dev:3552020-09-04 12:21:23.357 pm infoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:3552020-09-04 12:21:23.355 pm infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:3552020-09-04 12:21:23.318 pm debugdirty model = 545df2981b704114945f6df1c780515a, clean model=545df2981b704114945f6df1c780515a
dev:3552020-09-04 12:21:23.287 pm debugsendZigbeeCommands(cmd=[he raw 0x7B66 1 0x01 0x0000 {10 00 00 04 00}, delay 2000])
dev:3552020-09-04 12:21:23.273 pm infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:3552020-09-04 12:21:23.266 pm debugrecoveryMode: Slow
dev:3552020-09-04 12:21:23.224 pm infoRecovery feature ENABLED
dev:3552020-09-04 12:21:23.223 pm debugstartCheckEventInterval()
dev:3552020-09-04 12:21:23.156 pm infogetDriverVersion() = v0.8.1.0830
dev:3552020-09-04 12:21:23.154 pm debugrefresh() model='545df2981b704114945f6df1c780515a'
dev:3552020-09-04 12:21:23.150 pm infoupdated()
* endpointId: **01**
* application: **31323130363130325F37302E302E3176**
* model: **545df2981b704114945f6df1c780515a**
* manufacturer: **欧瑞博**
