org.quartz.SchedularException error at midnight
Error message at ~12:00:20am each night:
hubitat org.quartz.SchedulerException: Based on configured schedule, the given trigger 'app5Recur.allHandlerT' will never fire. on line 7603 (method timeHandler)
Hub: C7 @ platform version 2.3.3.140
The above error message is in the log each night a few seconds after midnight. Does "app5" refer to a specific app/rule, if so, where do I look up which app/rule entry that is referring to.
Thanks,
-Eric
Yes. To figure it out, either:
  • click/tap the red "error" box, which will open the app in question directly; or
  • click/tap the "app:5" text, which will filter the logs to just this particular app and highlight its name at the top (the two places you can filter by name), which should also help you figure it out
Excellent - thanks for that pointer. If in that RuleMachine 5.1 App had a trigger for a specific day/time that has now passed, would that be what caused that error to be flagged? I've deleted those now-passed triggers and updated the rule.
That sounds consistent with the error, yes.
