Orbit Sprinkler Controller Going Offline
Sven and I have had the Orbit go offline several times. Here is the log from the Orbit that I pulled just now.
Does anyone know what this means and why it would all of a sudden start disconnecting. I am on 125 but it didn't do this on 119.
dev:1942019-08-24 10:57:34.307 am traceReceived on/off report
dev:1942019-08-24 10:57:34.305 am debugParse: read attr - raw: 6EDA0700060800001000, dni: 6EDA, endpoint: 07, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00
dev:1942019-08-24 10:57:33.802 am debugParse: catchall: 0104 0006 07 01 0040 00 6EDA 00 00 0000 0B 01 0000
dev:1942019-08-24 10:57:18.255 am traceReceived on/off report
dev:1942019-08-24 10:57:18.252 am debugParse: read attr - raw: 6EDA0700060800001001, dni: 6EDA, endpoint: 07, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01
dev:1942019-08-24 10:57:16.020 am debugParse: catchall: 0104 0006 07 01 0040 00 6EDA 00 01 1039 0B 01 0300
dev:1942019-08-24 10:56:56.152 am debugParse: catchall: 0104 0006 0C 01 0040 00 6EDA 00 00 0000 07 01 00
dev:1942019-08-24 10:56:54.133 am debugParse: catchall: 0000 8021 00 00 0040 00 6EDA 00 00 0000 00 00 A100
dev:1942019-08-24 10:56:52.144 am debugParse: catchall: 0104 0006 0B 01 0040 00 6EDA 00 00 0000 07 01 00
dev:1942019-08-24 10:56:50.128 am debugParse: catchall: 0000 8021 00 00 0040 00 6EDA 00 00 0000 00 00 9F00
dev:1942019-08-24 10:56:48.136 am debugParse: catchall: 0104 0006 0A 01 0040 00 6EDA 00 00 0000 07 01 00
dev:1942019-08-24 10:56:47.559 am traceReceived on/off report
dev:1942019-08-24 10:56:47.556 am debugParse: read attr - raw: 6EDA0C00060A00001000, dni: 6EDA, endpoint: 0C, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:47.050 am traceReceived on/off report
dev:1942019-08-24 10:56:47.048 am debugParse: read attr - raw: 6EDA0B00060A00001000, dni: 6EDA, endpoint: 0B, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:46.562 am traceReceived on/off report
dev:1942019-08-24 10:56:46.559 am debugParse: read attr - raw: 6EDA0A00060A00001000, dni: 6EDA, endpoint: 0A, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:46.117 am debugParse: catchall: 0000 8021 00 00 0040 00 6EDA 00 00 0000 00 00 9A00
dev:1942019-08-24 10:56:46.046 am traceReceived on/off report
dev:1942019-08-24 10:56:46.044 am debugParse: read attr - raw: 6EDA0900060A00001000, dni: 6EDA, endpoint: 09, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:45.556 am traceReceived on/off report
dev:1942019-08-24 10:56:45.552 am debugParse: read attr - raw: 6EDA0800060A00001000, dni: 6EDA, endpoint: 08, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:45.045 am traceReceived on/off report
dev:1942019-08-24 10:56:45.043 am debugParse: read attr - raw: 6EDA0700060A00001000, dni: 6EDA, endpoint: 07, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:44.543 am traceReceived on/off report
dev:1942019-08-24 10:56:44.541 am debugParse: read attr - raw: 6EDA0600060A00001000, dni: 6EDA, endpoint: 06, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:44.134 am debugParse: catchall: 0104 0006 09 01 0040 00 6EDA 00 00 0000 07 01 00
dev:1942019-08-24 10:56:44.044 am traceReceived on/off report
dev:1942019-08-24 10:56:44.042 am debugParse: read attr - raw: 6EDA0500060A00001000, dni: 6EDA, endpoint: 05, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:43.544 am traceReceived on/off report
dev:1942019-08-24 10:56:43.543 am debugParse: read attr - raw: 6EDA0400060A00001000, dni: 6EDA, endpoint: 04, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:43.042 am traceReceived on/off report
dev:1942019-08-24 10:56:43.038 am debugParse: read attr - raw: 6EDA0300060A00001000, dni: 6EDA, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:42.544 am traceReceived on/off report
dev:1942019-08-24 10:56:42.542 am debugParse: read attr - raw: 6EDA0200060A00001000, dni: 6EDA, endpoint: 02, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:42.122 am debugParse: catchall: 0000 8021 00 00 0040 00 6EDA 00 00 0000 00 00 9000
dev:1942019-08-24 10:56:42.043 am traceReceived on/off report
dev:1942019-08-24 10:56:42.038 am debugParse: read attr - raw: 6EDA0100060A00001000, dni: 6EDA, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:1942019-08-24 10:56:40.128 am debugParse: catchall: 0104 0006 08 01 0040 00 6EDA 00 00 0000 07 01 00
dev:1942019-08-24 10:56:40.041 am traceReceived voltage level report 25.5
dev:1942019-08-24 10:56:40.035 am debugParse: read attr - raw: 6EDA6400010A200020FF, dni: 6EDA, endpoint: 64, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: FF
dev:1942019-08-24 10:56:39.951 am debugsending refresh command
dev:1942019-08-24 10:56:38.124 am debugParse: catchall: 0000 8021 00 00 0040 00 6EDA 00 00 0000 00 00 8B00
