It seems weather is a in a bit of an upheavel with weather undeground etc.
I setup openweathermap and it seems to work fine, however, it seems other than humidity and temp, there really isn't much available to action on, even though more comes back from the api.
What am I missing?
I have weather switch by @Cobra (who is awesome!) but it doesn't seem that the fields it uses work off the open weather device.
Very simply I'd just like an automation to turn on more lights when its overcast, openweathermap has a "cloudiness" value but it doesn't appear its exposed anywhere?
I'm trying to reconcile how it all goes together and weather seems a bit fractured. If anyone can suggest some work arounds or direction I would be so grateful!
Honestly, I don’t know but I do believe @bangali driver and @Cobra WU driver share many of the same attributes. I’m sorry, I’m not at home so I can’t check to make sure.
I have apixu a try and that seems to expose a few mor items, still seems silly the native OpenWeatherMap map doesn’t, is that code anywhere? Happy to modify it to add that ability
Apart from a couple of virtual demo drivers, Hubitat drivers and apps are closed, not open source.
So, unfortunately no, the drivers code is not released.
I have just released a new version of Weather Switch which should be ably to switch on 'Cloud Cover' 'coudiness'
I warn you though that I don't have a device to test this with so in theory it should work... but..
