Thank you for this. This is the first that I have heard that multiple people are having the same issue. I have not been able to replicate the issue so it is hard to troubleshoot this. It would be helpful if someone who is having this issue could send me a screen shot of the Preferences (including any Options Attributes) they have set. Also if they could turn on 'Extended logging' and see if there are any warnings or errors listed there, and send those too. You may PM those if you don't to post them in this thread.
Bug fix for myTile not showing icon when neither the 'Three day Forecast Tile' nor the 'Forecast High/Low Temperatures' Optional attributes are selected.
Thank you @maxq10 for helping to locate the issue.
If using HPM do an Update or a repair. Otherwise open the driver code and re-import the code. Thanks.
I must be missing something (aka lost). Most of my dashboard is simple and fits my needs, but I've never done this before. I added the code from Github. I created a virtual device using that code and a key, which I can see it's going to OWM and getting the results.
But I'm not getting the attributes I see in this thread. I'm unsure if I'm missing a step or loaded the wrong code. The end goal is to add this to my dashboard (jpage4500), where I have everything else. Any guidance would be greatly appreciated.
When you set the driver in your virtual device, make sure to scroll past all the system drivers to the custom user drivers at the bottom of that list. Then select this driver. It looks like you have the integrated system OWM driver selected.
I have installed the OWM driver and created a virtual device with that driver. I have created an account and copied the API into the virtual device. I have turned on some features - 3day forecast. I cannot set any attributes on the Dashboard?? What am I missing.
