In fact there are no "rain" attributes available to me in the "set variable' dialogue, although all of them are available in the "trigger" dialogue. Some other attributes seem to be missing too (although at the moment it's only the rain I'm interested in)
Nope...deleting the Device and recreating it made no difference. There are many more attributes available in the "trigger" dialogue than there are in the "set variable" dialogue
forecastHigh = Today's High
forecastHigh1 = Tomorrow's High
forecastHigh2 = Day After Tomorrow's High
forecastLow = Today's Low
forecastLow1 = Tomorrow's Low
forecastLow2 = Day After Tomorrow's Low
@Matthew Opened up a question about interpretation of the feed as it pertains to today on the GitHub .. Curious your thoughts, Im probably misunderstanding this.
Good afternoon all been having issue with the driver this morning throwing errors. It turns out that the Poll Sunrise-Sunset: [uri:https://api.sunrise-sunset.org/json?lat=44.313788&lng=-78.285709&formatted=0&date=2022-04-16, timeout:20. Certificate expired last night? Till they publish a new one, OWM-alert is not going to function. Im not a real good prorgamer, but would it not be better to get sunrise and sunset from OWM oncall api? The driver is polling OWM and getting Json data back but because of the failure of sunset api all is broken. Just saying.
The poll gets more than Sunrise and Sunset times. The more detailed responses are used for the Lux calculations. At this point I will give them some time to update thier certificate and hopefully that resolves the issue. If that poll cannot be completed a more substantial re-write will be required and the lux calculations will be less accurate.
Edit 1: Last successful poll for me was 2022/04/15, 21:08 MDST
Edit 2: When I went to the https://sunrise-sunset.org site directly in my browser, an expired certificate warning was given, which I accepted & continued... Running the provided link by @daniel.barrie2 above DID however give a valid return:
Tried a different browser; once the expired certificate message is accepted, valid data is returned and there are no further certificate prompts. Hope this is useful...
I'm also seeing a lux value of 5 - and the logs tell that something is happening but I'm not sure what it implies (the current lux measured from an external camera is 805)
I use Lux in rules to determine if lights are needed in certain places - it's not really damaging to my world since a motion lighting RM not being stopped from triggering is a small issue... not sure where to look about this...
I made a couple of minor edits in the driver and it has stopped the errors for now and every thing else seemed to keep working. The errors aren't really hurting anything, but since I added the error monitor app I now get a push notification every time I refresh the weather device. I have an app that refreshes the weather driver fairly often and I got annoyed by the error notifications.
