Here is some rough code. Paste into the Driver Code section, save and then go to Devices and add a virtual device with the Open Garage as the device type (should be at/near the bottom of the list).
Code
* Open Garage
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
import groovy.json.JsonSlurper
static String version() { return '0.0.1' }
metadata {
definition (
namespace: "thebearmay",
author: "Jean P. May, Jr.",
importUrl:"https://raw.githubusercontent.com/thebearmay/hubitat/main/xxxx.groovy"
capability "Actuator"
capability "Polling"
attribute "door", "string"
attribute "distance", "number"
attribute "vehStatus", "string"
attribute "rssi","number"
command "close"
command "toggleDoor"
command "rebootDevice"
preferences {
input("devIP", "string", title: "IP of the Open Garage Device", width:4)
input("devPwd", "password", title: "Device Password", width:4)
input("pollRate","number", title: "Polling interval in seconds (0 to disable)", width:4)
input("debugEnable", "bool", title: "Enable debug logging?",width:4)
def installed() {
log.trace "Open Garage v${version()} installed()"
device.updateSetting("devIP",[value:"192.168.4.1",type:"string"])
device.updateSetting("devPwd",[value:"opendoor",type:"password"])
device.updateSetting("pollRate",[value:0,type:"number"])
def updated(){
log.trace "updated()"
if(debugEnable)
runIn(1800,"logsOff")
else
unschedule("debugEnable")
if(pollRate > 0)
runIn(pollRate, "poll")
else
unschedule("poll")
void close() {
if(debugEnable) log.debug "closing.."
httpGet(
uri: "http:$devIP",
path: "/cc?dkey=$devPwd&close=1",
headers: [
Accept: "application/json"
) { resp -> }
runIn(10,"poll")
void toggleDoor() {
if(debugEnable) log.debug "toggle door.."
httpGet(
uri: "http://$devIP",
path: "/cc?dkey=$devPwd&click=1",
headers: [
) { resp -> }
runIn(10,"poll")
void rebootDevice() {
if(debugEnable) log.debug "rebooting.."
httpGet(
path: "/cc?dkey=$devPwd&reboot=1",
headers: [
) { resp -> }
runIn(30,"poll")
void setStatus(dStat){
sendEvent(name:"door", value:dStat)
void updateAttr(String aKey, aValue, String aUnit = ""){
aValue = aValue.toString()
sendEvent(name:aKey, value:aValue, unit:aUnit)
void poll(){
httpGet(
path: "/jc",
headers: [
) { resp ->
try{
if (resp.getStatus() == 200){
if (debugEnable)
log.debug resp.data
def jSlurp = new JsonSlurper()
Map retData = (Map)jSlurp.parseText((String)resp.data)
processJc(retData)
}catch (ex) {
log.error "$ex"
void processJc(dMap){
updateAttr("distance", dMap.dist, "cm")
if(dMap.door == 1)
updateAttr("door","open")
else
updateAttr("door", "closed")
if(dMap.vehicle == 1)
updateAttr("vehStatus", "present")
else
updateAttr("vehStatus", "not present")
updateAttr("rssi", dMap.rssi, "dBm")
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
