Onkyo Receiver Custom Driver
I finally got a driver for my Onkyo receiver working! I have a couple of receivers in my house, so one thing I need to figure out is how to set the IP address of each device dynamically. I added an IP preference, but it only shows up in one of the devices I create.
In the second one it's not showing up.
Is there another way, without creating two DTH's, to reuse the same DTH for multiple devices while setting the IP separately for each device?
 *  Onkyo IP Control Device Type for Hubitat
 *  Carson Dallum (@cdallum)
 *  Originally based on: Mike Maxwell's and Allan Klein's code
 *  Usage:
 *  1. Be sure you have enabled control of the receiver via the network under the settings on your receiver.
 *  2. Add this code as a device handler in the Hubitat Drivers Code section
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * Some future commands that might be useful to incorporate reading:
 * Power Status: PWRQSTN
 * Input Selected: SLIQSTN
 * Volume Level: MVLQSTN (value in hex)
 * Artist Name: NATQSTN
 * Track Name: NTIQSTN
 * Zone 2 Mute: ZMTQSTN
 * Zone 2 Volume: ZVLQSTN
 * Zone 2 Input Selected: SLZQSTN
 * ISCP commands were found at https://github.com/miracle2k/onkyo-eiscp/blob/master/eiscp-commands.yaml
metadata {
	definition (name: "Onkyo Receiver (Family Room)", namespace: "cdallum", author: "Carson Dallum") {
	capability "Initialize"
    capability "Telnet"
    capability "Switch"
	command "cable"
	command "stb"
	command "pc"
    main "switch"
    details(["switch","cable","stb","pc"])
def on() {
	log.debug "Powering on receiver"
	sendEvent(name: "switch", value: "on")
	def msg = getEiscpMessage("PWR01")
    return new hubitat.device.HubAction(msg,hubitat.device.Protocol.TELNET)
def off() {
	log.debug "Powering off receiver"
	sendEvent(name: "switch", value: "off")
	def msg = getEiscpMessage("PWR00")
def cable() {
	log.debug "Setting input to Cable"
	def msg = getEiscpMessage("SLI01")
def stb() {
	log.debug "Setting input to STB"
	def msg = getEiscpMessage("SLI02")
def pc() {
	log.debug "Setting input to PC"
	def msg = getEiscpMessage("SLI05")
/* This is where I construct the entire message character by character. Each char is represented by a 2 disgit hex value */
def getEiscpMessage(command){
	def sb = StringBuilder.newInstance()
	def eiscpDataSize = command.length() + 3  // this is the eISCP data size
	def eiscpMsgSize = eiscpDataSize + 1 + 16  // this is the size of the entire eISCP msg
	sb.append("ISCP")
	// the following are all in HEX representing one char
	// 4 char Big Endian Header
	sb.append((char)Integer.parseInt("00", 16))
	sb.append((char)Integer.parseInt("10", 16))
	// 4 char  Big Endian data size
	// the official ISCP docs say this is supposed to be just the data size  (eiscpDataSize)
	// ** BUT **
	// It only works if you send the size of the entire Message size (eiscpMsgSize)
	// Changing eiscpMsgSize to eiscpDataSize for testing
	sb.append((char)Integer.parseInt(Integer.toHexString(eiscpDataSize), 16))
	//sb.append((char)Integer.parseInt(Integer.toHexString(eiscpMsgSize), 16))
	// eiscp_version = "01";
	sb.append((char)Integer.parseInt("01", 16))
	// 3 chars reserved = "00"+"00"+"00";
	//  eISCP data
	// Start Character
	sb.append("!")
	// eISCP data - unittype char '1' is receiver
	sb.append("1")
	// eISCP data - 3 char command and param    ie PWR01
	sb.append(command)
	// msg end - this can be a few different cahrs depending on your receiver
	// my NR5008 works when I use  'EOF'
	//OD is CR
	//0A is LF
	[CR]			Carriage Return					ASCII Code 0x0D
	[LF]			Line Feed						ASCII Code 0x0A
	[EOF]			End of File						ASCII Code 0x1A
	//works with cr or crlf
	sb.append((char)Integer.parseInt("0D", 16)) //cr
	return sb.toString()
// General App Events
def initialize(){
	telnetConnect("192.168.1.xxx", 60128, null, null)
	log.debug "Opening telnet connection"
def installed(){
	initialize()
def updated(){
	initialize()
Couple of items on this.
telnet should include capability "Initialize"
Then move all the telnetConnect code into def initialize(){telnetconnect here...}, I'm surprised it even runs where you currently have it, pauseExecution isn't required.
Initialize is called when the hub starts up, if you then include initialize within updated, then any ip changes will restart telnet.
telnetClose should be removed as it's not needed, you want the connection open all the time.
The parse method code isn't doing anything, you can remove all of it as these aren't lan messages, first place to start with that is to dump the output and see whats coming back.
You will need a separate driver for each device you have.
Yes I can open a Telnet connection to my Denon receiver. Could you please provide a telnet example in the public repo?
Thanks for the tips. I'll make these changes and see how it works.
Regarding some of your advice, I picked up information from other posts. Sounds like these items aren't needed, though, so I'll go ahead and remove them. :+1:
TelnetClose()
PauseExecution(1000)
The link posted pretty much covers it, the remainder is grunt work consisting of collecting and formatting the commands and parsing the responses.
I'll be releasing the Onkyo driver in the next build (1.1.5)
I updated my driver code per @mike.maxwell recommendations. Enjoy!
Yeah, just add a preference option for the ip, then use that in the telnet connect.
I don't see an option to pick the IP Address like your screenshot shows on the code posted above, do I have to update it in the driver itself?
For now I hard-coded the IP address in the most recent version of the code. There's likely a more elegant solution but I wanted to get it working to deprecate my ST hub. Since I have two Onkyo receivers I created two versions of the driver code, each with it's own IP address.
Was this driver ever included in 1.1.5 or 1.1.6?
It was not.
Ok, driver will be out in the next build.
This is awesome Mike thanks. Is play/pause/seek possible thru this or is that handled somewhere else?
Thats not available to all onkyo receivers, so I can't really include it in this one.
It might be possible to handle this via an ad hoc custom command, you would need to know the relevent commands.
Is there a list of Onkyo Receivers that has Telnet that will work with this integration?
Official Onkyo telnet integration / driver built into Hubitat!! I knew Mike was knowledgeable on this subject but didn't see this one coming! Wow! Hubitat for the win!!
Turn on and off, set input Source and set Volume are the variables I would like to use and this has them!
Should work any of them that have an ethernet port.
I built this driver against a pr-sc5530, I have an older pr-sc885c that I will test with in the next few days.
Denon driver will be tested this weekend.
I hate to ask a stupid question, but since the receiver is neither z wave or zigbee, how do i add a tcp/ip device such as my Onkyo receiver?
On the Devices page click the "Add Virtual Device" button. and select "Onkyo AVR" for the device type:
Enter a Device Name, Network ID and Label and click Save Device.
