One year later: My love for Hubitat is melting
This is the latest figure I have and is for 2019. The source is....Fibaro itself, so I know that one can doubt these data but other data in the same sheet seemed to correlate well with other sources.
Fact is that Fibaro was (by far) the most important supplier of Z-wave devices in Europe until they were acquired by Nice, a move that benefited the wallet of the founders of the Fibarogroup but was the beginning of the end for the users who had considered Fibaro as a trutsworthy supplier for end-users. Right now Fibaro hubs can only be successfully installed by professional installers, unless you have the skills and will to code your home-automation yourself.
Thanks Boris, I just replied to him...
Hey neonturbo,
Thanks for your reply.
I DID get an acknowledgement of my messages to support but that was the last I heard , never an answer to the question.
For the forum, yes, I think the fact that North-America is the origin of the majority is one of the causes. I just wonder what the plans of Hubitat are: they are strongly promoted by some European domotics-stores but that should be followed up with a regular chack of the European market to see if Hubitat is still a goodcoice for Europeans too or not.
Hey Bryan,
I told the story about the Fibaro wall plugs in an earler reply to you. An other example are the Fibaro motion sensors; both zwave and zwaveplus versions are sometimes very diificult if not downright impossible to include an this in a random way: some of them are included very fast and are working fine, others can never be included, still others will include but don't report motion or very erratically: they go to 'active' and stay there for hours and hours while nobody is home and then suddenly after 8 or 9 hours return to 'inactive'. And, as I said, others work normally. I must say I changed my Netgear Nighthawk Router to a RS750 Netgear mesh system that has a every powerful 'backhaul' connection between the satellites. So I uncoupled the Orbi mesh system and put back my Nighthawk router but that didn't chenge anything. Which was to be expected as the problems with the wall plugs and the motion sensors started BEFORE I installed the Netgear Mesh system.
Hey Neonturbo,
You see: this topic is ,a perfect illustration of it's own title ("my love for Hubitat melting away"). We are several weeks further now and what have we got ? Several replies from people who wanted to help but didn't follow up on their initial good intentions, the topic was also hijacked by other persons discussing some completely unrelated techincal nerd-issues, absolutely no input from hubitat staff and members with 'special knowledge' about things didn't answer anymore after I gave them the extra information they asked for. So, that's why my enthusiasm is further melting and I ordered an other hub just a few days ago.
@wienog this sounds a prime example of a weak z-wave mesh along with.
A driver is nothing to do with the join process or really even Hubitat. That's all handled by silicon labs firmware with Hubitat providing the UI and responses. Have you updated to the latest release though and update that firmware, if not already I would advise you do. For me it has improved loads of things even though because I have so many powered devices I didn't have a "problem". But everything works faster and the device are not constantly moving around and randomly missing a event.
@bcopeland can you assist with his question on the driver though and the lack of support for the EU version apparently.
Personally I have had similar experiences with fibaro stuff like the dimmer 2 it's never fully been supported but think that's because it's not used much/ at all in USA
A correlation between the Wi-Fi network and the poor performance of Z-Wave network is not causation. Based on the details provided above, as others indicated, the symptoms are those of an overloaded mesh. As @bcopeland pointed out earlier, the problems may be related to the drivers.
Our engineers have tested different versions of the models you own, so there is highly likely that they run different firmware versions than those that we have tested.
In the ideal world, a manufacturer wouldn't produce different versions of the same basic model, but more often than not, big companies like Fibaro are known to release variations of the same model that are different enough to cause problems - another company that comes to mind is Schlage.
Using models that have been tested by our engineers, is the best way to avoid any issues. Sending us devices so that our engineers can test and adjust drivers based on the firmware variation, is another way.
Of course if enough customers report problems with a specific model that is running a different firmware, then our engineers run out and purchase the specific model so they can adjust the driver (or remove the model altogether from the List of Compatible devices, which happened to Schlage locks).
I am not sure if @bcopeland was able to find the specific version you have, so I'll let him provide an update on that.
P.S. if you didn't update to the latest version of the Z-Wave firmware, please do so as soon as possible. It has been confirmed to significantly improve the Z-Wave perfomance in busy environments.
If you have any specific models that are not supported properly.. The best method is to have the manufacturer send us an engineering sample for us to write a proper driver. We receive devices from manufacturers all over the world, but they tend to send only their latest models.
We are happy to support anything, but need the device in hand to properly write a driver.
I haven't really seen it mentioned here but it possibly contributing to your issues. I see that some of the devices that are showing LWR RSSI, have a very low signal, as in negative. Missed messages, and re-acks can really hamper your mesh. Routing through a bunch of weird paths because of low signal can make it even worse. The LWR RSSI stat is cleared after a reboot.
If you haven't already, update the firmware for the zwave radio? There will be a button to do so up by "Z-Wave Topology". After that, can you go and manually trigger the devices that aren't showing an LWR RSSI to repopulate them and post the screenshots again?
