When I try to set a local DateTime variable in one app, I get no time operation options. I can only "Cancel this action":
If I choose another variable that is a number or boolean in the same app I get set options .
In another app I get my time options:
Any thoughts on what is going on?
I wonder if the rule might be corrupted…. The times I saw that, it was the issue and re-creating the rule was the solution.
That's what I was afraid of. It's my longest rule, and it will probably take me over an hour to recreate it.
Ouch! You could always download a backup, then restore an earlier backup from when you could edit it and export the rule. Then restore the latest backup and import the rule.
I was about go through older backups, when I saw 2.3.1.130 was available. Upon updating, the issue went away. I didn't roll back to check if that was the definitive fix and will simply give offerings to the software gods for my good fortune.
