The migration from my C-7 to C-8 did not work. First, I could not copy the file but then then after loading your update (2.3.7.143) I was able to copy the file to backup. But after putting the new C-8 hub in, all devices are coming up disabled. I tried to enable them but the still don't work. All my devices (are Z-Wave) were working prior to the change from C-7 to C-8. Devices are Aerotech ZWA038-A Switches, ZOOZ 800 SERIES Z-WAVE Scene Controller Switches ZEN32, ZOOZ Outdoor Motion Sensor ZSE29 Ver 2.0 and ZOOZ ZSE44 Humidity and Temperature Sensor. I had to put the C-7 back in to get my lights working.
You are using a cloud backup that includes the radio data, correct? A local backup would not contain the radio data.
Make sure you are following:
Eric I am just using Z-Wave to talk to my devices.
OK, so you want to make sure the cloud backup that you are using includes the Z-Wave radio data. Something like this (one of my older hubs that only runs Z-Wave) -
Did you follow the migration instructions and use a migration backup in the cloud system?
You said something about "copying" a backup file, a locally downloaded backup file will not move the zwave radio data over, so devices will not work. You must follow the instructions and use a cloud migration backup.
