I'm moving from a dead C4 to a C7 hub -- one gotcha I've run into is I have a few old GE-JASCO ZW4101 outlets -- on the C4 these devices would report physical events, on the C7 they don't -- just digital. (I've done several configure/refresh/Zwave repair cycles).
The default driver is Generic ZWave Outlet. It's possible that on the old hub I'd replaced this with a different/user driver, but if so I don't remember what it was.
Discussion I find in the community seems to indicate I need to use the ZWave-Poller app -- but the outlets don't show up in the lists of available devices in that app.
Any advice? I'm thinking I probably just need to put these in a box and buy some ZWave Plus replacements
Z-Wave switches/dimmers/outlets do not report a change in their status except some devices made by Leviton that made use of Hail, which made the controller poll them to query status.
GE/Jasco Z-Wave devices did not use Hail.
So there are two possibilities here:
You used a different driver on the C-4 (a switch driver) that permitted these devices to be added to the Z-Wave poller app.
That they are not ZW4101, but the similar looking GE/Jasco 45703, which is a Z-Wave+ device, but you are using the wrong driver for it on the C-7.
Thanks @HAL9000 -- I think you're right -- I must've had the Poller running on the old hub, though I don't remember setting it up. And you're also right about switching the driver to Generic ZWave Switch -- making that change caused the devices to appear in the Poller's list. Setting all that up and a RM rule using the physical switch capability and it works again - thanks very much for your help
Thanks @aaiyar -- definitely the ZW4101 (or at least that's what's printed on the back of the device) -- using the Generic ZWave Switch driver instead of the Outlet driver did the trick, this must've been what I had set up in the C4 -- thanks very much for your help.
