I am noticing anodd thing. I have 5 sengled zigbee flood lights w/motion. One of them regularily dims it self. I have no apps telling it too. The other 4 are fine. Anyone see anything like this?
Have you looked at the Events page for this device (plus any Zigbee groups it might be in, e.g., Groups and Scenes or Room Lighting) to see for sure? Look for entries of type "command," as noted in the doc I linked to (not so much events, which will likely be a boring account of what actually happened and that you already know; commands will tell you if something on the hub did it).
Tons of entries like this, it is doing it on it's own. The handful of apps that interact with it only turn it on and off. Flood office rear is it's name.
I think I will replace the bulb as a test, I have a couple extras
I decided to write 2 rules, one sets the brightness to 100% and turns it on, the other to turn it off. I added a hub variable/switch that everything uses to turn it on and off, which is the trigger for those rules. Seems to work well
