NuHeat Signature provides integration of NuHeat floor thermostats with Hubitat.
This is a new integration based on the latest OAuth2 API for NuHeat.
The integration consists of a connection application, and a device that presents itself to Hubitat as a thermostat device.
This integration supports multiple NuHeat thermostats per installation. The connect app automatically creates the devices it discovers.
The nuHeat Signature thermostat should be already configured and operating properly with the nuHeat website and mobile app prior to enabling this integration. This integration does rely on the nuHeat cloud/APIs.
You do need to request OAuth2 information from NuHeat, see the GitHub link below to see the instructions for this.
Current Release Updated October 18, 2026
First device release May 17, 2020
Installation and Updating
This is available via HPM
Or you can install the connect application and device driver by hand
Thanks for posting the integration! I installed the driver and can access my NuHeat thermostats - I'd like them to go into standby mode based on a Rulemachine condition (away-mode) but I have not been able to figure out how. Is that possible with your integration?
Thanks - I am able to get it into indefinite hold now, but I don't seem to be able to resume. Do you mind letting me know what the parameter/value is to accomplish this?
Thanks for porting this. Have a question/comment. In command "setHeatingSetpointWithHoldTime" it brings up a date picker, based on the Nuheat phone app hold times are based on hours with a max of 23 hours. Is there something I'm missing
I just checked her code and it looks like it'd be a heavier lift. Adding that one line in yours did the trick for me but maybe there are unintended consequences that I don't understand. In any case, I was hoping it was an easy fix but it sounds like not. I do now also see that you had this commented out on line 36 so I'm just uncommenting it at the moment so the InfluxDB Logger sees the NuHeat Thermostat as a Thermostat and passes the attributes over to the DB.
If there are unintended consequences of that that I should look out for, I'm all ears. Thanks anyway!
Is anyone aware of an IP-only version for this device that will not require it to be connected to the actual internet? Just the home network by IP address?
OJ Microline makes a similar thermostat with essentially the same properties, perhaps even mostly the same parts. I wonder if this integration can be adapted to enable control of those thermostats? ojelectronics.com/UWG4
