From reading previous forum posts, HE C7 sets its internal clock using Network Time Protocol accessing Google’s NTP servers. The NTP Client driver (NTP Client / Local NTP Server support) provides setting the clock from another device, such as a LAN-based NTP server. Both the native C7’s NTP request and the driver can coexist and run in parallel. Is the proceeding still correct? (Most of the info I found on this topic is 1+ years old.)
Also, I installed the above driver using the Hubitat Package Manager and specifying the URL of the package path to its packageManifest.json file. I had to use the URL of the raw code (on github.com) to install the driver, otherwise I received an “Invalid Package File“ message. Do I use the raw URL when installing any packages – drivers and apps?
(HE Rev C-7 firmware version 2.3.0.124)
