I created a Notifier to announce repeatedly when a door is open. It works, announcing every minute as long as the door is open. The problem is that it sometimes won't stop.
This picture shows how I have it set up: Notify when it's open, repeat every minute, then stop on the next event.
But sometimes it keeps repeating, even when the door is closed. I can see the little green LED on the door sensor flash when I close the door, so I know the sensor is being triggered (in addition to it starting the notification when it opened and in addition to the dashboard showing it closed). So it seems like a setup or software problem.
BTW, I don't want to limit it to repeat only a few times or for a period of time. Assuming I can get it working correctly, I want it to repeat until I notice the door's open.
As a second question: How do I reset it? I've tried pausing the rule, but it sometimes resets it and sometimes doesn't, so the repeating announcement returns.
