Is there a way to use a notification received by my phone to turn on a switch in Hubitat
Not natively--the Hubitat mobile app does not support "actionable notifications," nor does any third-party solution I'm aware of. But it's possible I'm missing something there; perhaps someone who uses one of those can chime in.
Tasker is probably your best bet, if you use Android phones. You would need to use AutoNotification I think as well.
Not on your phone per se (but you could have the notification go to both), but you could set up a virtual notification device that is also a switch, maybe something like:
Notification Switch Code
* Notification Switch
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WIyTHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
static String version() { return '0.0.1' }
metadata {
definition (
namespace: "thebearmay",
description: "Simple Switch that is turned on via a Notfication.",
author: "Jean P. May, Jr.",
importUrl:"https://raw.githubusercontent.com/thebearmay/hubitat/main/notifySwitch.groovy"
capability "Notification"
capability "Switchโ
capability "Configuration"
attribute "notificationText", "STRING"
command "configure"
preferences {
input("debugEnable", "bool", title: "Enable debug logging?")
input("toggleDelay","number", title:"Seconds before turning off switch (Zero=off)",defaultValue:0)
def installed() {
log.trace "installed()"
configure()
def updated(){
log.trace "updated()"
if(debugEnable) runIn(1800,logsOff)
def deviceNotification(notification){
sendEvent(name:"notificationText", value: notification)
on()
def on(){
sendEvent(name:"switch",value:"on")
if(toggleDelay) runIn(toggleDelay,"off")
def off(){
sendEvent(name:"switch",value:"off")
def configure() {
off()
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
Here's an example of what I was talking about....
