Notification frequency
Greetings,
Simple question (refreshing, right??)
Using Notifications, "How frequently do you want to be notified", one can set 0 to 59 minutes, or once per 24 hr period.
So........
Does this app not allow selections between those times?
Say........ I want 2 hours, or 3 hours?
Bill
No, right now it has to be under 60 minutes. Presumably, they could add this feature--it would just take a bit more coding/logic to do. (My guess if they're doing a naïve conversion to a cron string and accounting for just minutes was the easiest option, and I actually seem to remember a bug in the past where it let you use any value but only worked for values under 60, presumably because this is exactly what it was doing.)
Ahhhhaaa @bertabcd1234 Sir...
Thank u, thank u, and of course..
The most difficult thing for me, trying to learn heavily, is that searching this excellent community, & the docs, does not pull up an answer. Esp to a simple question like this. I get tons of everything else... I spend hours...
Guess its back over to RM 5.1...
Thank u Sir...
Bill
