It had nor shown up yet, but did when I manually checked for updates. Installing now, we'll see if that helps.
Success! Stuff is working again! Not sure 100%, but a bunch of different things started working. Including my front door open alarm, which given the door is gone (it is getting replaced right now), is a good thing.
Running 2.2.9.134. Hub freezes after a few minutes when i soft reset. Trying to update to .140 causes the hub to reset.
Please update to 2.2.9.144.
I meant 2.2.9.144. It downloads, does the update thing but is still running 2.2.9.134 after the reboot. System messages in the top right still says to download 2.2.9.144 but if click on it the hub reboots.
Please go to the diagnostics tool on port 8081, pick Restore previous version, and select 2.2.9.144 from the list. Once updated to 144, this issue will not manifest going forward.
seems to be working. Thank you
