Not Everything Turns Off
Good morning, all!
Hubitat C-8 non-Pro, running 2.4.4.135
The Situation: Up until a week or so ago, I was running a lot of dimmable LED lamps ("bulbs") on plug-in dimmers, either Lutron through the Lutron hub, or Leviton Zigbee dimmers. One very low wattage LED is in a lamp run by a Third Reality smart Zigbee plug. All was fine. My Rules were running like clockwork.
What I did: For various reasons including scratching my experimenter itch I decided to dig out a hoard of Third Reality RGBW lamps and get rid of the dimmers. They are in floor lamps, each of which have 3 bulbs. I added them all with no problems, then made each of those three-bulb lamps into a group. "Living Room Floor Lamp E Lower" and the other two into a group called Living Room Floor Lamp E".
The Problem: My Rule Machine scripts used to turn things on and off perfectly. Now, some individual bulbs will remain on, either in the floor lamps or sometimes the night light. I am attaching both the morning startup Rule, which works perfectly, and the morning shutdown, which sometimes does not shut everything off. Please note: The TV corner floor lamp has regular bulbs and runs on a Minoston plug-in dimmer.
Any ideas? Break things up with "Wait" to let the C-8 "catch up"? Is there some setting I am missing? Thanks, gang!
When I had a C-5 hub I had a rule that turned off a bunch of lights. And sometimes not all of them would actually turn off. I split that action into two, with half the lights in the first action and the other half in the second, and I put a 1-second delay on the second action. And all of the lights turned off reliably after that. Now I have a C-8 Pro, but I've never changed that rule because it ain't broke. So you might try something like that.
Somehow, at the back of my mind, I suspected tossing in some time delays, even a little one, would solve this problem. This suspicion is now confirmed. Why? Because my night-time shutdown routine simulates someone walking through the house, shutting things off. [this lamp] off. Wait for 30 seconds. [that lamp goes off]. Wait for 12 seconds. [the other lamp] goes off and so forth.
Just a question. Is Delay any different from Wait?
Yes. Delay just delays subsequent actions by the indicated and preconfigured delay time.
Wait halts the rule until an event occurs or an expression becomes true.
For this use case I wouldn't think that it made a great deal of difference.
I just found Delay to be handy so used it and I'm not trying to simulate a person turning the lights out. One thing to note in general is that Delay has to be explicitly cancelled. There's a write-up on Delay and Wait in the Rule 5.1 documentation here.
Check into the device driver and enable retry logic.
I have seen a similar problem on one of my networks. The other network is newer 800 type devices and all off all on commands run within a few seconds (2-3) for 30 or so end devices. The other network is a mix of old and new about 50/50 and it is slightly bigger network with 50 or so devices. This network take 20-35 seconds to process an all on all off ( an sometimes it stubles even longer). RSSI on the bigger network is a bit lower (and more notably PERs are higher) which may compound the problem. The problem house had metal boxes and conduit for house wiring (Chicago thing)nwhich might also be a factor.
I tried delays, grouping like devices together and handling groups one at a time, enabled logic so it only tuns on/off if it isn't in that state, supervision,... None of it helped much. Still poor response. I looked at the ZWave logs but an all on/off generates about 200-300 lines of logs so not the easiest to review. Sadly my 10 year old Vera (since retired) handled this pool of devices better than Hubitat does...
You are not alone if that helps any.........
