Looking for some advice on how to query a temp sensor and send a notification on the query.
I have a temp sensor in my swim spa and all I want to do is send a pushover notification once a day with the queried temp. The only thing I’m able to find is to send notification if temp changes or equals something. Is there a way to just query a device for temp and send a notification on its value?
There's a Rule Machine 5.1 bug in using the "Set Variable" action that manifests on a C-7, but not a C-5. Observed by @inetjnky on a C-7 and reproduced on my C-7.
Do you have any variables on the affected hub? The action will be hidden unless you do. You may also need to "Done" your way out of and back into the rule if you created your first one while you had it open and it's a hub variable rather than local (not exactly sure when it fetches this list but seem to recall something along those lines).
I suspect this is the root of the OP's issue as well.
