Which node do I need to trigger a flow based on time? I can't see one (but I may not have it installed in the pallete)
Use an 'inject' node.
You can set the time at the bottom.
I use the cron-plus node.
BigTimer is another popular choice.
Hmm not sure what's gone wrong. I've tried to install cron-plus from the palette but it errors saying I already have it installed (but I don't)
Edit: Ignore that. I did a node-red-restart via ssh and it's appeared.
I'm a fan of this node ... due to the flexibility that cron offers.
I use ezTimer where I want to trigger a flow at a specific time. Very simple to and combines on/off schedules in one node. I also use cron-plus where I want to trigger a flow on a schedule (every 5 minutes, 5 minutes past the hour etc.)
