this is a little hard to explain but i got a ceiling fan that has 2 pull cords to turn on the light and the speed of the fan. does anyone know how if possible to turn it to a "smart" ceiling fan? the light switch is a normal On/Off switch so i could put a "blank" pad face on the switch.
That’s fairly typical so not hard to understand. The answer is yes you can.
The options you have depend on how many wires run from the box containing the switch you mentioned to the fan. Is it two or three conductor (green/bare wire doesn’t count at all)?
The now discontinued Hampton Bay Fan Controller could do this. Inovelli is probably the next closest thing, but they aren't in stock right now.
Innovelli fan switch
I think there is 3 ok I'll look into this thank you guys
have you got any links? i know they out of stock but just for reference
ah cheers this was the one i was looking at. thanks. im guessing these have been out of stock for a while
They'll be back soon. Worth waiting for
Here is another good option, local control available via Bond API...
Universal Smart Wi-Fi 4-Speed Ceiling Fan Remote Works with Google Assistant, SmartThings, and Alexa (homedepot.com)
