I have been reading that there is support for nPC with Hubitat, and I am considering purchasing a Hubitat to try it out. I already have nPC up and running wonderfully via a local web interface dashboard. Before I purchased a hub I thought I would check in on this project first.
Some older threads mention @brad2 and some awesome work he did a few years ago on this topic. I was going to attempt to follow along.
Is this still possible, and are there any guides/writeups that I should read up on? Thanks!!!
This is working fine for me with Habitat and njPoolController. I have been running the code as published in Habitat Package Manager all year this year and it's working great.
I see that CS7's are readily available for cheap. Since I currently have only network devices (nPC on a RPI, Nest products, and a future Konnected alarm) any concerns with going with the older Hubitat to get started?
Hi @brad2 . I have used your hubitat integration for a couple years without issue. I have also setup on a friends system without issue. However, mine stopped working recently so I completely removed the app and reinstalled, but neither the autodiscovery nor manual configuration methods are working. I have also tried to add directly from the rPi that njsPC is installed on without luck. DashPanel discovers njsPC without issue. Any thoughts on how to resolve?
@farside847 the c7 works great and shouldn't be an issue with the dvices you mentioned. Keep in mind that it does not have wifi on board so will need to be hardwired to your network.
I was having issues until I changed the DIN of the poolController device to match the IP address of the rpi running njsPC.
From what I've read, I think the HE devices DIN must match either the senders IP address or mac address. I think that address gets created at the HE poolController install time.
So, I think you need to manually change the DIN for the poolController if
you change the rpi hardware and the HE poolController DIN was matching the MAC address of the RPI
or--
you change the IP address of the sending RPI, if the poolController DIN matched the RPI ip address
Anyway, when I changed the HE poolController DIN to match the rpi ip address, everything started working.
