Ok so Day 2 of Node Red, so on the steep part of the curve
I have got NR up and running and have it working with HE .
Primarily working on the Heating System
So have this below to detect when ANY Thermostat is calling for Heat and turn on the boiler.
See below for an export (Not sure how to put this export in post - sorry if wrong)
So if ANY of the Thermostats goes to heating the boiler turns on.
QUESTION
In Node Red how do I get it to TURN OFF BOILER when ALL the Thermostats are showing idle?
Any input ideas - clues very much appreciated.
"id": "9383dd8c4d34f669",
"type": "tab",
"label": "Turn On Off Boiler",
"disabled": false,
"info": "Interim Flow to detect when heating is called for in HE and turn on the Boiler",
"env": []
"id": "d87e7d5e03bbf6f4",
"type": "switch",
"z": "9383dd8c4d34f669",
"name": "",
"property": "payload.value",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "heating",
"vt": "str"
"t": "eq",
"v": "idle",
"vt": "str"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 3,
"x": 670,
"y": 540,
"wires": [
"775c084b941ebd8d"
"id": "775c084b941ebd8d",
"type": "hubitat command",
"deviceLabel": "ZW006",
"name": "Radiator Boiler",
"server": "76f91883bed98728",
"deviceId": "422",
"command": "on",
"commandArgs": "",
"x": 900,
"y": 520,
"wires": [
"6abc0f046064224a"
"id": "6abc0f046064224a",
"type": "debug",
"name": "heat detected",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1120,
"y": 520,
"wires": []
"id": "e82ea9344efa129a",
"type": "hubitat device",
"deviceLabel": "Thermostat Controller Bathroom",
"name": "",
"deviceId": "865",
"attribute": "thermostatOperatingState",
"sendEvent": true,
"x": 350,
"y": 380,
"wires": [
"d87e7d5e03bbf6f4"
"id": "4684922b64e44dda",
"deviceLabel": "Thermostat Controller Guest Bedroom",
"name": "",
"deviceId": "814",
"sendEvent": true,
"x": 330,
"y": 425.7142857142857,
"wires": [
"d87e7d5e03bbf6f4"
"id": "515f191ea950f377",
"deviceLabel": "Thermostat Controller Guest Ensuite",
"name": "",
"deviceId": "866",
"sendEvent": true,
"x": 330,
"y": 471.42857142857144,
"wires": [
"d87e7d5e03bbf6f4"
"id": "27f3d173900d8cb3",
"deviceLabel": "Thermostat Controller Kitchen",
"name": "",
"deviceId": "869",
"sendEvent": true,
"x": 350,
"y": 517.1428571428571,
"wires": [
"d87e7d5e03bbf6f4"
"id": "358705e1b8481de8",
"deviceLabel": "Thermostat Controller Landing",
"name": "",
"deviceId": "874",
"sendEvent": true,
"x": 350,
"y": 562.8571428571428,
"wires": [
"d87e7d5e03bbf6f4"
"id": "272b2be6de6a46b4",
"deviceLabel": "Thermostat Controller Lounge Back",
"name": "",
"deviceId": "870",
"sendEvent": true,
"x": 340,
"y": 608.5714285714284,
"wires": [
"d87e7d5e03bbf6f4"
"id": "979ebce6c012ee14",
"deviceLabel": "Thermostat Controller Master Bed",
"name": "",
"deviceId": "867",
"sendEvent": true,
"x": 340,
"y": 654.2857142857141,
"wires": [
"d87e7d5e03bbf6f4"
"id": "d86bad211bedf718",
"deviceLabel": "Thermostat Controller Molly",
"name": "",
"deviceId": "868",
"sendEvent": true,
"x": 360,
"y": 700,
"wires": [
"d87e7d5e03bbf6f4"
"id": "a67776542bbf69d6",
"deviceLabel": "Office/Spare Temperature SRT",
"name": "",
"deviceId": "577",
"sendEvent": true,
"x": 350,
"y": 760,
"wires": [
"d87e7d5e03bbf6f4"
"id": "76f91883bed98728",
"type": "hubitat config",
"name": "HE Heating",
"usetls": false,
"host": "10.10.10.7",
"port": "8080",
"appId": "1162",
"nodeRedServer": "http://192.168.1.36:1880",
"webhookPath": "/hubitat/webhook",
"autoRefresh": true,
"useWebsocket": false,
"colorEnabled": false,
"color": "#ace043"
