I have a large sequence that I would like to replace all the delay nodes with timer nodes (so I can see how much time is left). Is it possible you replace nodes in mass rather than deleting and remapping each one?
I have never done this but you could theoretically export your flows to a file and then do a replace of the Node IDs based on the file and reimport. Seems kind of scary (insert new sucking sound here).
