As of this morning, I'm down to 3 apps left on my Hubitat (to talk to garage door, presence, and ecobee)
I turned off the app that auto reboots the hub every morning a week ago, it hasn't needed it, that's been nice!
I'm still fighting with some things, like for instance the combination of light switches and motion sensors in 3 different rooms, I think I just may be overthinking them (i hope!). there has been nothing worse than walking into a room wondering why a light is already on lol
Has anyone found a way of getting TTS with a good choice of voices on NR?
In Hubitat I use "Brian" who sounds like a traditional English Butler. We like that, and the whole automation system is now referred to as Jeeves. So I want to retain his voice for all TTS both to Google Minis and Sonos Play.
SonosPollyTTS allows the "Brian" voice for the Sonos, but I couldn't find a way of getting anything other than an especially whiny female voice via Google TTS. There is PollyTTS but that just gets the TTS as a file that doesn't pass to the Minis. At the moment I still fire all TTS commands back to HE and get it to do the output, but that means replacing all spaces in the string with hyphens so it's a bit of a pain.
If an all NR solution is available I would much prefer it.
Have you looked at SSML (Speech Sythesis Markup Language)? The Alexa palette I use allows for use of it. However, I cannot get it to work using the Cast palette to my Google Mini but this page on Google's website seems to indicate it is possible: https://cloud.google.com/text-to-speech/docs/ssml
If you get it to work, you have to share. In my short research, it would seem that a node from this palette, node-red-contrib-google-tts, sending to a cast node, node-red-contrib-cast, should work but I can't figure it out yet.
Mapping using the OwnTracks and worldmap nodes is pretty neat. Works well enough to map my movements within the building I work in. It shows in my office and also indicates most other rooms that I was in this morning - except when I was out of cell/WiFi range (the building's a concrete behemoth).
Node-RED servers need some time to sync the package with npm
You refresh the browser to see the update
if you wonder why the version is not available, you can verify all these links to see where is the update (probably stuck on step 4)
Yeah I confirm that you can install new nodes without restarting Node-RED, but it's impossible to load updated nodes without restart. It's a technical limitation
Yeah so true, I would dedicate a lot of releases to him, but I wouldn't want to make others jealous
So only the sending of events.. if I wanted to just read all the values at once "undefined" gives an invalid attribute error so I still need multiple nodes of same device / different attributes.
Don't want to clog up the thread here with this stuff so may just submit something on Github.. appreciate the responses.
So what you really want is the equivalent of: Get Device Info (replace [Device ID] with actual subscribed device id
http://[Hub IP]/apps/api/[Maker API app ID]/devices/[Device ID]?access_token=xyz123
You could use an http request node to do that, but I understand you would rather the hubitat nodes have an option to do that.
Interesting... yes that what I want and yes that might be a way around it. I'm good with an NR solution but it would be nice to keep it within the palette..
Like maybe some input msg flag that sends everything in the cache. I can see a few uses for that... Deciding on the format of the payload would be interesting though.
I would vote for:
payload: {
attribute name 1: value,
attribute name 2: value,
But if we think we need dataType, etc, in there then it would have to be something similar to how Maker API returns the values, in an array. The bad part about that is that Maker API returns it with just an indexed array, so you have to check each element of the array to know what the attribute type is.
This is the Maker API response format. The array levels being indices are annoying:
If it came down to an array, doing it like Maker API could work - but with a twist... Just use attribute name for the array tree level instead of "0", "1", "2", etc. I "think" that is possible...
Then users could just do msg.payload.level.value or msg.payload.switch.value, etc. And not have to search or walk the array to find the value they want.
Yeah the list is annoying to parse .. it was on my todo list to change the way to store internal data exactly as you propose. And I think it's a good idea to expose it like this
Considering that it takes me 10 times longer to write in English than writing code, then your help is a huge contribution of real work
