This is something I worked on a while ago. It may help.
[{"id":"3f814648.830bda","type":"ui_slider","z":"8c249630.076968","name":"","label":"Office Hue","tooltip":"","group":"57bd8750.b32dc8","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":0,"max":"100","step":"5","x":630,"y":600,"wires":[["9e3d9c15.728d6"]]},{"id":"c6acccbb.0ea2b","type":"template","z":"8c249630.076968","name":"On","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"on\":true,\"brightness\":{{payload}} }","output":"json","x":890,"y":600,"wires":[["58ce48aa.b93d48"]]},{"id":"94d591c1.5b387","type":"change","z":"8c249630.076968","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.brightness","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":560,"wires":[["29d106f0.a3ee1a"]]},{"id":"29d106f0.a3ee1a","type":"rbe","z":"8c249630.076968","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1490,"y":560,"wires":[["3f814648.830bda"]]},{"id":"58ce48aa.b93d48","type":"hue-group","z":"8c249630.076968","name":"Mike's Office","bridge":"5e6fe1ca.85689","groupid":"3","colornamer":true,"skipevents":false,"x":1050,"y":600,"wires":[["36cf9319.34314c"]]},{"id":"36cf9319.34314c","type":"switch","z":"8c249630.076968","name":"","property":"payload.on","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1190,"y":600,"wires":[["94d591c1.5b387"],["e623ee4e.41f81"]]},{"id":"e623ee4e.41f81","type":"change","z":"8c249630.076968","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":600,"wires":[["29d106f0.a3ee1a"]]},{"id":"9e3d9c15.728d6","type":"switch","z":"8c249630.076968","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":770,"y":600,"wires":[["b37b8be7.3e8e28"],["c6acccbb.0ea2b"]]},{"id":"b37b8be7.3e8e28","type":"change","z":"8c249630.076968","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":560,"wires":[["58ce48aa.b93d48"]]},{"id":"57bd8750.b32dc8","type":"ui_group","name":"Downstairs","tab":"1862e313.45ffad","order":15,"disp":true,"width":"4","collapse":false},{"id":"5e6fe1ca.85689","type":"hue-bridge","name":"Philips hue","bridge":"192.168.1.221","key":"76VF5utXrkJ9PftxiZgEDKW3dFB67Mv8H1Op4RQA","interval":"3000","disableupdates":false},{"id":"1862e313.45ffad","type":"ui_tab","name":"Mike","icon":"dashboard","disabled":false,"hidden":false}]
People have been quiet about this feature request recently
