Anyone using Go Control garage door and Node-RED? I'm trying to figure out what the difference is between "sensor" and "door" in the device node and is one more reliable than the other?
I get a ton of "false" open/close events in HE (it appears to be related to temperature changes) and I've sort of worked around them in RM but wanted to check if anyone had suggestions of which event to use in Node-RED. Thanks!
