I am getting the following error in the log.
2019-03-26 09:37:28.300 am errorgroovyx.net.http.ResponseParseException: Bad Gateway on line 274 (refresh)
Anyone know what this is?
Bad gateway is a HTTP 502 error. Are you seeing this in @aaron's app?
@razorwing - this error usually means you coordinates are outside of the USA. Where are you located? Can you PM me the URI that shows in the logs when debugging is enabled?
It is coming from the NOAA Weather App.
The error has not re-occurred since 10:02 AM so not sure if it will or not. The error occurred when I had NOAA Weather App set to 30 minutes. It is now set to 10 minutes and the error has not come back. Could it be something to do with the 30 minute selection?
Not sure as the error means that HE attempted to query weather.gov and had an issue. I will probably implement a catch error to prevent the error.
Thanks aaron. I haven't seen it again since I set it to 10 minutes. The error as I said occurred with the 30 min selection. Not sure why. As you said probably just a timing thing.
@aaron We just received a severe thunderstorm warning here so that worked great...Thank you!
I have the poll frequency set to 5 minutes and the repeat alerts set to 3 minutes. We got one alert but no repeats. A setting?
Glad you got the severe weather alert. The last update I did some changes for repeating the alert. Let me look into that again.
This is the my current Dashboard tile (notice the date) it still doesn't seem to clear the messages when the alerts expire?
Did you install the latest version of the app and driver? I had an alert yesterday and it cleared after 5 minutes.
I think so it was after we talked about this the other day.....mine says version 2.1.9
What about the tile driver?
Tile driver is version 1.2.0
Run a test alert. Should reset after your desired time.
Fixed, thank you and sorry @razorwing for interrupting and getting aaron sidetracked.......
@waynespringer79 No problem, we all need to get it working, it has become very important to have.
@aaron Thanks for looking into it.
I am traveling but should be able to root out issue in next few days. Just confirming: are you on latest version?
2.2.0 - fixed repeat issues - can be tested with issuing a test alert
Also can you post in the original NOAA Weather app thread for future support. Appreciate the help in knocking out these bugs.
@aaron I am on 1.2.0 for Tile and 2.1.9 for App. Upgrading now. Will post in original Thread.
