You were probably using a custom driver previously for this device. That driver probably created a scheduled job, which is still scheduled but does not have a "handler" available in the stock driver you appear to be using now.
To fix, switch temporarily to the "Device" driver, run the "Delete All Scheduled Jobs" command, then switch back to the Generic Zigbee Outlet driver or whatever one you intend to use for that device.
