Initially there was no "Parsed descMap" in the log, but an error popped up (I don't know if relevant):
errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_muxa_Zemismart_ZigBee_Wall_Switch_Multi_Gang_588.logsOff() is applicable for argument types: () values: []
Possible solutions: logInfo(java.lang.Object), off(), notify() (method logsOff)
After a new pairing it show this:
dev:1372023-04-15 08:34:42.535debugAtrio Parent createChildDevices
dev:1372023-04-15 08:34:42.534debugAtrio model: TS0011 buttons: 0
dev:1372023-04-15 08:34:42.530debugAtrio Parent deleteChildren
dev:1372023-04-15 08:34:42.529debugAtrio Parent setupChildDevices
dev:1372023-04-15 08:34:42.523debugAtrio sendZigbeeCommands : [he raw 0xEFF3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xEFF3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xEFF3 0x01 0x01 6 {A4C13813CDF5E141} {}, delay 2000, he cr 0xEFF3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xEFF3 0x01 6 0 {}, delay 2000]
dev:1372023-04-15 08:34:42.515debugAtrio configure()..
dev:1372023-04-15 08:34:42.513infoAtrio InitializeVars()... fullInit = true
dev:1372023-04-15 08:34:42.512debugAtrio Initializing...
dev:1372023-04-15 08:34:37.161infoAtrio Turning all child switches on
dev:1372023-04-15 08:30:26.765infoAtrio Turning all child switches on
dev:1372023-04-15 08:30:24.965infoAtrio Turning all child switches off
dev:1372023-04-15 08:30:23.912infoAtrio Turning all child switches on
dev:1372023-04-15 08:30:20.026debugAtrio sendZigbeeCommands : [he raw 0xEFF3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xEFF3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xEFF3 0x01 0x01 6 {A4C13813CDF5E141} {}, delay 2000, he cr 0xEFF3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xEFF3 0x01 6 0 {}, delay 2000]
dev:1372023-04-15 08:30:20.019debugAtrio configure()..
dev:1372023-04-15 08:30:19.402infoAtrio Turning all child switches on
dev:1372023-04-15 08:30:18.888infoAtrio Turning all child switches off
dev:1372023-04-15 08:30:18.132infoAtrio Turning all child switches on
dev:1372023-04-15 08:30:05.724warnZemismart ZigBee Wall Switch Multi-Gang parseBasicClusterAttribute cluster:null UNKNOWN attrId FFDF value:«¬!ÚM9ÔSÔ
dev:1372023-04-15 08:30:05.716debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:EFF30100003ADFFF4219AB18000012AC21000012DA4D00001239D400001253D4000016, dni:EFF3, endpoint:01, cluster:0000, size:3A, attrId:FFDF, encoding:42, command:0A, value:«¬!ÚM9ÔSÔ, clusterInt:0, attrInt:65503] (description:read attr - raw: EFF30100003ADFFF4219AB18000012AC21000012DA4D00001239D400001253D4000016, dni: EFF3, endpoint: 01, cluster: 0000, size: 3A, attrId: FFDF, encoding: 42, command: 0A, value: 19AB18000012AC21000012DA4D00001239D400001253D4000016)
dev:1372023-04-15 08:30:05.048debugZemismart ZigBee Wall Switch Multi-Gang Attribite FFE4 : 00
dev:1372023-04-15 08:30:05.045debugZemismart ZigBee Wall Switch Multi-Gang Attribite FFE2 : 33
dev:1372023-04-15 08:30:05.043debugZemismart ZigBee Wall Switch Multi-Gang Applicaiton version: 43
dev:1372023-04-15 08:30:05.037debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:EFF30100001801002043E2FF2033E4FF2000, dni:EFF3, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:33, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]] (description:read attr - raw: EFF30100001801002043E2FF2033E4FF2000, dni: EFF3, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 43E2FF2033E4FF2000)
dev:1372023-04-15 08:30:04.395debugZemismart ZigBee Wall Switch Multi-Gang Parent switch off
dev:1372023-04-15 08:30:04.389debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:EFF30100060A00001000, dni:EFF3, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: EFF30100060A00001000, dni: EFF3, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00)
dev:1372023-04-15 08:30:02.390debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
dev:1372023-04-15 08:30:02.385debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 EFF3 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFF3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]] (description:catchall: 0104 0006 01 01 0040 00 EFF3 00 00 0000 07 01 00000000)
dev:1372023-04-15 08:30:00.374debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
dev:1372023-04-15 08:30:00.368debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 8021 00 00 0040 00 EFF3 00 00 0000 00 00 D600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:EFF3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D6, 00]] (description:catchall: 0000 8021 00 00 0040 00 EFF3 00 00 0000 00 00 D600)
dev:1372023-04-15 08:30:00.255debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
dev:1372023-04-15 08:30:00.250debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0000 01 01 0040 00 EFF3 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFF3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] (description:catchall: 0104 0000 01 01 0040 00 EFF3 00 00 0000 04 01 00)
dev:1372023-04-15 08:30:00.091debugZemismart ZigBee Wall Switch Multi-Gang Model Identifier: TS0011
dev:1372023-04-15 08:30:00.089debugZemismart ZigBee Wall Switch Multi-Gang Applicaiton version: 43
dev:1372023-04-15 08:30:00.087debugZemismart ZigBee Wall Switch Multi-Gang ZLC version: 03
dev:1372023-04-15 08:30:00.084debugZemismart ZigBee Wall Switch Multi-Gang Manufacturer name: _TZ3000_ji4araar
dev:1372023-04-15 08:30:00.067debugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:EFF301000068040042105F545A333030305F6A693461726161720000002003010000204305000042065453303031310700003003FEFF003000, dni:EFF3, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_ji4araar, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:43, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0011, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] (description:read attr - raw: EFF301000068040042105F545A333030305F6A693461726161720000002003010000204305000042065453303031310700003003FEFF003000, dni: EFF3, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6A693461726161720000002003010000204305000042065453303031310700003003FEFF003000)
dev:1372023-04-15 08:30:00.056infoZemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = false
dev:1372023-04-15 08:30:00.052debugZemismart ZigBee Wall Switch Multi-Gang updating the settings from the current driver Zemismart ZigBee Wall Switch Multi-Gang version null to the new version 0.5.1 2023/04/05 7:27 AM [model TS0011, manufacturer _TZ3000_ji4araar, application 43, endpointId 01]
dev:1372023-04-15 08:29:59.769debugZemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands : [he raw 0xEFF3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xEFF3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xEFF3 0x01 0x01 6 {A4C13813CDF5E141} {}, delay 2000, he cr 0xEFF3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xEFF3 0x01 6 0 {}, delay 2000]
dev:1372023-04-15 08:29:59.759debugZemismart ZigBee Wall Switch Multi-Gang configure()..
dev:1372023-04-15 08:29:59.751infoZemismart ZigBee Wall Switch Multi-Gang model TS0011, manufacturer _TZ3000_ji4araar, application 43, endpointId 01
dev:1372023-04-15 08:29:59.749infoZemismart ZigBee Wall Switch Multi-Gang Parent installed, typeName Zemismart ZigBee Wall Switch Multi-Gang, version 0.5.1 2023/04/05 7:27 AM, deviceNetworkId EFF3, zigbeeId A4C13813CDF5E141
The zigbee log showed two device while pairing, one that's the appropriate device and another without ID that I suppose is what you are referring to.
