I started using the Galaxy Wear app for my Smartthings hub quite a bit over the last year. As I started changing over to Hubitat I went looking for it, and none to be found?
Searching the forum, there isn't even many hits on it...What gives?
There is no Wear app for Hubitat.
I use Google Assistant on my watch to control my devices via voice if I want to.
You can also use the Google Home app on your watch to control your devices if you add them to Google Home via the built-in or the community integration.
Those two options have served my needs.
If the watch handles web short cuts you can also use that for control.
