I need to install smart lighting along a roadway, my lighting vendor is proposing a nLight rTLN. It says it uses the following protocols:
Operating Voltages: 120-277VAC or 347/480VAC
Frequency: 50/60 Hz
RF: Transmit Power 900Mhz: +20dBm, Max 1000ft Clear LOS; 2.4GHz: +10.4 dBm,
Max 100ft Clear LOS
Wireless: Standard 900MHz: IEEE 802.15.4-based
2.4GHz: Version 4.0+ of the Bluetooth specification
Can the hubitat control this? I known 802.15.4 2.4GHz, could be zigbee, but I am not certain that it is zigbee.
If this works, I will be purchasing at least one new hub (maybe more depending on the location of the lights).
