Nitebird WiFi LED Strip
Hello all,
I have had these for a while:
h-t-t-p-s://www.amazon.com/gp/product/B07XCVGL42/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I have them setup with the gosund app and they work pretty well.
I searched around on the forum about adding them to HE but I can only find info about flashing gosund smart plugs to a 'Tasmota' firmware, which isn't what I need (I think).
Any chance these are supported?
They are not directly supported because this is part of the Tuya line of WiFi smart devices. Tasmota firmware is a way to open up the capabilities of Tuya-based WiFi products.
There is a template for that device but it has a caveat on it. if the latest firmware is not on it you can flash it and use this template. It is a bit of process but pretty easy if you follow some of the youtube videos on it. (example - Tuya-Convert on Windows - Use VMware to flash Tuya devices! - YouTube )
NiteBird 9.2ft RGB TV Backlight LED Strip (SL1-1) Template for Tasmota
cheers
This is awesome, thank you!
