Reading the manual, no need to go so extreme, with the C connected in the inclusion it makes the device to be a repeater, removing the C wire during inclusion it makes the device to be an end device.
Nop, the only features I see different is the mapping (the circle, it has squares too like zensys), packet analyzer and the spectrum analyzer. It has wifi so you can connect directly to the tool from the smartphone.
This is something that I had on my Vera with the AltUI. So in theory, we most likely have this information already in Hubitat, it just needs to be presented. This is how it looks in AltUI:
Yes, and granted, it is not something I used a lot, but it was nice to see the relationships a few times a year or when adding new devices. I guess that is the reason that some buy Xbee for Zigbee.
I discovered that after you add a z wave device, even at its the final location, a z wave repair most be done. The last 2 devices I installed were 2 Qubino dual relays and both only had 2 routes, after the repair they got multiple routes. I thought pairing in its final location was enough.
Interesting. Now that you mention it, it looks a lot like my old Edge. I wonder if I could actually use my old Vera for this purpose ? I would have thought I needed to have the devices connected to the controller running the software.
