Nexia Doorbell Sensor (DB100Z)
Hi I paired my Nexia Doorbell Sensor with Hubitat but I'm unsure what device type to set it as. Can anyone help me?
I was looking around and found the smarttthings device driver here: SmartThingsPublic/nexia-doorbell-sensor.groovy at master · DarwinsDen/SmartThingsPublic · GitHub
But was unable to get it to work in hubitat as its been a while since I tinkered with groovy and when i did it was just stuff I read on the forums, Any way any help would be appreciated.
I use this one. I believe all I did was find and replace "physicalgraph" with "hubitat". If it still doesnt work for you let me know and I'll post the whole code.
Ok thanks I will give it a try
Also change "Button" to "PushableButton"
Ok I did It thanks. I will have to test it out tomorrow as my wife just got home with a headache and doesn't want me ringing the door bell >.>
Did this ever work?
Yes it did thank you.
Can you still post it? I am having trouble getting it to work.
Thanks!
 *  Nexia Doorbell Sensor - DB100Z
 *  Copyright 2016 DarwinsDen.com
 *  For installation instructions, DB100Z device review information, documentation and images,
 *  or for questions or to provide feedback on this device handler, please visit:
 *      darwinsden.com/db100z
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *    Author: Darwin@DarwinsDen.com
 *    Date: 2016-03-26
 *    Changelog:
 *  1.4 (05/10/2018) -  Added contact sensor as capability for use with smart home monitor
 *  1.3 (09/25/2016) -  Added display of firmware version and updated to get battery level on initial installation
 *  1.2 (09/11/2016) -  Added preference option for push-to-break button (vs. default push-to-make) doorbell circuit. Note: enabling
 *                      this setting will also result in a doorbell notification if power is lost to the doorbell transformer.
 *  1.1 (05/11/2016) -  Added Button capability option.
 *    1.0 (03/26/2016) -    Initial 1.0 Release.
metadata {
    definition (name: "Nexia Doorbell Sensor", namespace: "darwinsden", author: "Darwin") {
        capability "Actuator"
        capability "Switch"
        capability "Momentary"
        capability "PushableButton"
        capability "Contact Sensor"
        capability "Sensor"
        capability "Battery"
        capability "Refresh"
        capability "Configuration"
        attribute "status", "enum", ["off", "doorbell"]
        fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x86, 0x72, 0x5A, 0x73, 0x80, 0x70, 0x71, 0x85, 0x59, 0x84, 0x7A"
    simulator {
    preferences {
        input "pushToBreak", "bool", title: "Doorbell circuit is push-to-break instead of push-to-make",  defaultValue: false,  displayDuringSetup: true, required: false
    tiles(scale: 2) {
        multiAttributeTile(name:"status", type: "generic", width: 6, height: 4){
                tileAttribute ("device.status", key: "PRIMARY_CONTROL") {
                    attributeState "off", label: "Off", icon:"st.Home.home30", backgroundColor:"#ffffff"
                    attributeState "doorbell", label: "Ringing", icon:"st.alarm.alarm.alarm", backgroundColor:"#53a7c0"
        valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
            state "default", label:'${currentValue}% battery', unit:""
        standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
            state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
        valueTile("firmwareVersion", "device.firmwareVersion", width:2, height: 2, decoration: "flat", inactiveLabel: false) {
            state "default", label: '${currentValue}'
        main "status"
        details(["status", "battery", "refresh", "firmwareVersion"])
def refresh() {
       sendEvent(name: "status", value: "off", displayed: false, isStateChange: true)
       sendEvent(name: "switch", value: "off", displayed: false, isStateChange: true)
       updated()
       configure()
def configure() {
   log.debug ("configure() called")
   def commands = []
   commands << zwave.versionV1.versionGet().format()
   commands << zwave.batteryV1.batteryGet().format()
   delayBetween(commands,500)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
    def event = createEvent(descriptionText: "${device.displayName} woke up", displayed: false)
    def result = []
    // Request battery info on wake up if levels have not been received within last 24 hours
    if (!state.lastBatteryReport || (new Date().time) - state.lastBatteryReport > 24*60*60*1000) {
       result += response(zwave.batteryV1.batteryGet().format())
       result += response("delay 1200")
    result += response(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
    return result
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
    //updateDataValue("applicationVersion", "${cmd.applicationVersion}")
    log.debug ("received Version Report")
    log.debug "applicationVersion:      ${cmd.applicationVersion}"
    log.debug "applicationSubVersion:   ${cmd.applicationSubVersion}"
    state.firmwareVersion=cmd.applicationVersion+'.'+cmd.applicationSubVersion
    log.debug "zWaveLibraryType:        ${cmd.zWaveLibraryType}"
    log.debug "zWaveProtocolVersion:    ${cmd.zWaveProtocolVersion}"
    log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
    setFirmwareVersion()
    createEvent([descriptionText: "Firmware V"+state.firmwareVersion, isStateChange: false])
// Unexpected command received
def zwaveEvent (hubitat.zwave.Command cmd) {
       log.debug("Unhandled Command: $cmd")
       return createEvent(descriptionText: cmd.toString(), isStateChange: false)
def switchOffVerification() {
       if (state.bellIsRinging) {
            log.debug("${device.displayName} switchOffVerification setting switch off")
            sendEvent(name: "status", value: "off", descriptionText: "Button released via verification check", isStateChange: true)
       state.bellIsRinging = false
       sendEvent(name: "contact", value: "closed", displayed: false, isStateChange: true)
//Battery Level received
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
       def result = null
       state.lastBatteryReport = new Date().time
       def batteryLevel = cmd.batteryLevel
       log.info("Battery: $batteryLevel")
       result = createEvent(name: "battery", value: batteryLevel, unit: "%", descriptionText: "Battery%: $batteryLevel", isStateChange: true)
       return result
//Notification received
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
       def result = []
       // if the bell is not already ringing, record as a button press. We can't always trust an event of 1 to be a
       // button press if messages arrive out of order or are missed
       if (!state.bellIsRinging) {
           if (!pushToBreak | cmd.event == 0) //Event 1 will never be a doorbell trigger for a push to break circuit
             // bell is not ringing - signal a button press
             state.bellIsRinging = true
             log.debug("${device.displayName} notification event = $cmd.event triggered switch on")
             runIn(10, switchOffVerification) //set to turn off switch in 10 seconds in case the button release event is missed
             result += createEvent(name: "status", value: "doorbell", descriptionText: "Button pressed", isStateChange: true)
             result += createEvent(name: "switch", value: "on", displayed: false, isStateChange: true)
             result += createEvent(name: "momentary", value: "pushed", displayed: false, isStateChange: true)
             result += createEvent(name: "button", value: "pushed", data: [buttonNumber: "1"], displayed: false, isStateChange: true)
             result += createEvent(name: "contact", value: "open", displayed: false, isStateChange: true)
       } else {
           // bell is ringing - signal a button release
           log.debug("${device.displayName} notification event = $cmd.event triggered switch off")
           result += createEvent(name: "status", value: "off", descriptionText: "Button released", isStateChange: true)
           result += createEvent(name: "switch", value: "off", displayed: false, isStateChange: true)
           result += createEvent(name: "contact", value: "closed", displayed: false, isStateChange: true)
       return result
def setFirmwareVersion() {
   def versionInfo = ''
   if (state.firmwareVersion)
      versionInfo=versionInfo+"Firmware V"+state.firmwareVersion
   else
     versionInfo=versionInfo+"Firmware unknown"
   sendEvent(name: "firmwareVersion",  value: versionInfo, isStateChange: true)
def parse(description) {
      def result = null
      log.debug (description)
      if (description.startsWith("Err")) {
           result = createEvent(descriptionText: description, isStateChange: true)
      } else if (description != "updated") {
          def cmd = zwave.parse(description, [0x71: 3, 0x80: 1])
          if (cmd) {
              result = zwaveEvent(cmd)
          } else {
              log.debug("Couldn't zwave.parse '$description'")
      return result
def updated()
   log.debug ("updating")
   if (pushToBreak)
      state.pushToBreak = true
   else
      state.pushToBreak = false
Thanks @kilowatts !! worked first try. Notification to pushover and everything.
