Hi, new HE user here. I bought some cheap RGB Zigbee bulbs to experiment with, only $12. When looking at the device from the dashboard, the temperature field shows a limited range of 3000-6000. But I can click on a custom color in the palette (dark blue, red, etc) and the bulbs respond. So it seems these bulbs are capable of producing custom colors, but the bulb driver does accept values for "temperature" below 3000. Do more expensive bulbs offer the ability to set temperatures below 3000? The reason I ask is because as far as I can tell if I want to create a rule I have only two ways to set the color - pick from the limited colors in the drop-down menu, or specify the temperature.
Here are the bulbs I bought:
https://www.amazon.com/gp/product/B08N4LH7GD/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Any help appreciated, thanks.
