New Zigbee light switch
I also bought 2 switches from Lonsonho from Aliexpress. A wired zigbee no neutral 2-gang switch, and a wireless zigbee 3-gang switch.
I used the Generic zigbee switch drivers from this thread by @markus for the parent switches, and generic component switch for the child devices. The wired version was very easy. The wireless one was a bit fiddly.
I got a lot of info in the logs. On release the switches are switched off, but on press they're not switched on. I made a rule where each individual switch is switched on after going off. I also had to give the command in hubitat to switch them on the first time
Hey guys!
@arjen.wierda, @mmmaded were you able to get Yagusmart (X711 or X712 or X713) fully working?
I mean all the push, double-tap, hold, and release events work for you? Any downsides?
I did not test this, to be frank. I use them as normal light switches. They are connected to Hubitat so I can get Google to turn them on and off by voice.
I don't think this is available for these switches, as they are wired. Pressing a button just opens or closes the contact.
I also have this switch in wireless version. Both switches use the driver I referred to in my previous post as mother driver. Each button then gets a child driver which is a generic component switch. Pushing the button only toggles on or off, no other events.
This makes sense for the wired version but not for wireless :slight_smile:
Are you sure wireless buttons don't emitt these events or they are just not handled by the driver?
I don't seem to be able to ge this switch working with any drier like Nue or Generic Zigbee Switch.
This is the one I got but it's all the same: TuYa TS0001 control via MQTT | zigbee2mqtt.io
Do you have any suggestions how I can get this one working?
I know I am a little late to the game with this topic but my whole house has them, recently ported over from Smartthings into Hubitat and paired straight away. Had no issues since unlike occasional drop offs with Smartthings.
@mike.maxwell Hey Mike, I presume the EF00 cluster is still as unknown now as it was a year ago? I just bought a Tuya dimmer switch that is using that cluster and unable to find any existing drivers that work :slightly_frowning_face: The inClusters are: 0000,0004,0005,EF00
Afaik yes.
Hi,
This will work for Tuya 1 gang:
metadata {
definition (name: "MOES ZigBee Dimmer V.1.0 - Tuya 1gang", namespace: "CPS Smart Home", author: "Christos Psaroudis") {
    capability "Actuator"
    capability "PushableButton"
    capability "Configuration"
    capability "Refresh"
    capability "Sensor"
    capability "Switch"
    capability "Switch Level"
    fingerprint profileId: "0104", deviceId: "808F", inClusters: "0000,0004,0005,EF00", outClusters: "0019,000A", manufacturer: "_TZE200_9i9dt8is", model: "TS0601", deviceJoinName: "WorksWith Dimmer"
tiles(scale: 2) {
    multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true) {
        tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
            attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#79b821", nextState:"turningOff"
            attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
            attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#79b821", nextState:"turningOff"
            attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
        tileAttribute ("device.level", key: "SLIDER_CONTROL") {
            attributeState "level", action:"switch level.setLevel"
    standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
        state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
    main "switch"
    details(["switch", "refresh"])
// Parse incoming device messages to generate events
Map map = [:]
//def event = zigbee.getEvent(description)
if (description?.startsWith('catchall:')) {
    log.debug description
    // call parseCatchAllMessage to parse the catchall message received
    map = parseCatchAllMessage(description)
    if (map != [:]) {
        log.debug "ok send event: $map.name $map.value"
        sendEvent(name: map.name, value: map.value)
else {
    log.warn "DID NOT PARSE MESSAGE for description : $description"
def off() {
log.debug "called off"
zigbee.command(0xEF00, 0x0, "00010101000100")
def on() {
log.debug "called on"
zigbee.command(0xEF00, 0x0, "00010101000101")
def setLevel(value) {
log.debug "called setLevel with value $value"
if (value >= 0 && value <= 100) {
    //String commandValue = "0001020200040000" + zigbee.convertToHexString((value * 10) as Integer, 4)
    Map commandParams = [:]
    String commandPayload = "0001020200040000" + zigbee.convertToHexString((value * 10) as Integer, 4)
    zigbee.command(0xEF00, 0x0, commandPayload)
def refresh() {
log.debug "called refresh"
zigbee.command(0xEF00, 0x0, "00020100")
//pauseExecution(1000)
//zigbee.command(0xEF00, 0x0, "0002020200")
def configure() {
log.debug "Configuring Reporting and Bindings."
zigbee.onOffConfig() + zigbee.levelConfig() + zigbee.onOffRefresh() + zigbee.levelRefresh()
private Map parseCatchAllMessage(String description) {
// Create a map from the raw zigbee message to make parsing more intuitive
def msg = zigbee.parse(description)
Map result = [:]
switch(msg.clusterId) {
    case 0xEF00:
        def attribute = getAttribute(msg.data)
        def value = getAttributeValue(msg.data)
        switch (attribute) {
            case "switch":
                switch(value) {
                    case 0:
                        result = [
                            value: 'off',
                            data: [buttonNumber: 1],
                            descriptionText: "$device.displayName button was pressed",
                            isStateChange: true
                    break;
                    case 1:
                        result = [
                            value: 'on',
                            isStateChange: true
                    break;
            break;
    break;
return result
private String getAttribute(ArrayList _data) {
String retValue = ""
if (_data.size() >= 5) {
    if (_data[2] == 1 && _data[3] == 1 && _data[4] == 0) {
        retValue = "switch"
    else if (_data[2] == 2 && _data[3] == 2 && _data[4] == 0) {
        retValue = "level"
return retValue
private int getAttributeValue(ArrayList _data) {
int retValue = 0
if (_data.size() >= 6) {
    int dataLength = _data[5] as Integer
    int power = 1;
    for (i in dataLength..1) {
        retValue = retValue + power * _data[i+5]
        power = power * 256
return retValue
The mystery box was in:
def off() {
def on() {
For 2 gang you need to use 00010201000100 and 00010201000101
How did you came up with those magic numbers? Is there any documentation on it?
