I finally got my hands on Yale's upgraded push button Z-Wave Plus deadbolt model YRD136 (replaces the YRD110). The previous version uses the "Generic Z-Wave Lock" driver even though it currently isn't listed on the List of Compatible Devices page.
Has anyone been able to sync the device? I haven't been able to sync. I currently have the C7 Hub.
EDIT #2: Figured it out, posting here for anyone else. The inclusion/exclusion instructions provided in the documentation can be confusing depending on your device state.
Inclusion Configuration:
If you press and hold config button and it beeps 5x, then you need to complete a "Z-Wave Exclusion" first. Otherwise, move to step 2.
Holding down the config button it should only beep 2x, wait an additional 2 Mississippi before release.
Start "Z-Wave Inclusion" on Hubitat.
Inclusion/Exclusion: If at any point after letting the config button go and it throws a rapid warning chime, something went wrong repeat step.
The difference is the YRD156 is touchscreen and the YRD136 has physical push-buttons, both are Z-Wave Plus. It comes down to preference but the push-button versions are absolutely wonderful.
I like the look of the touchscreen - definitely "cleaner" (I have a YRD256) but in terms of operation my family actually prefers the push buttons on our Kwikset 912. The issue I have with the Kwikset is it only has 5 buttons so the code needs to be longer. Interestingly that shortcoming is part of the appeal for non-techie users it seems. Less imposing maybe?
