new website i have a ton of likes showing up as new. and dismiss all is greyed out?
dismiss on the pullodown sidebar worked.. but dismiss all on the page is greyed out as i said.
I am not sure I understand, mind sharing a screenshot the next time?
What @kahn-hubitat may be referring to is the likes section of the notifications in the Community.
The regular notifications sections looks fine... but likes seems to have what appear to be quite old likes.
Its old ones you never looked at to clear them, and the new design is pushing them to the top which I sort of like. It does the same with watched threads.
When you have as many like posts as me, it just becomes annoying... ![]()
Dismiss all, once should make them go away... Can't replicate an issue with Dismiss button.
yes exactly that dismiss button works.. i found out later.. but if you double click that list a bigger similar list comes up in the website instead of a popup and that Dismiss button doesnt work (is greyed out)
ie
That's not "disabled". It works if you select it. However, as it says is dismissing all, not only likes.
So as you see I have 2 notifications flagged as important:
When I click Dismiss All from Preferences I get an additional warning to make sure I really want to dismiss ALL ![]()
well it didnt work for me .. maybe it is now.. but when i had those 100s of likes it was greyed out. the other button eventually worked.. maybe there were too many and the page was not loading completely?
